Subject: Poser 11 pro and DSON importer problem
dante opened this issue on Apr 24, 2016 · 11 posts
dante posted Sun, 24 April 2016 at 11:36 PM
Hi folks... Here's the rub. I'm trying to use daz figures with DSON importer but the program just hangs after loading one, say Lee 6..I can move the figure, but I'm unable to use the content window...it loads fine, but after that it just hangs there...Any ideas? Thanks a lot.
hborre posted Mon, 25 April 2016 at 6:03 AM
Is your content library still docked? Undocking it will improve response. Also set the figure to SubD=0; the subdivided mesh demands addition resources and will slow down the app on older machines.
vitachick posted Mon, 25 April 2016 at 8:20 AM
undock content library? Thought that was only available in Poser2014.. Do tell how to show as external..Like it much better
Win10  Poser 2014/Poser 11 Daz3D
dante posted Mon, 25 April 2016 at 9:58 AM
It is allready undocked, I wonder if reinstalling DSON will resolve the problem...thanks folks
hborre posted Mon, 25 April 2016 at 10:36 AM
Oops, forgot that Poser 11 Pro already has an undocked content library. Do you have the latest SR installed?
adzan posted Mon, 25 April 2016 at 10:49 AM
Hi. The DSON option that shows information to a user as an item loads can cause problems with the Poser library and makes it unusable for some people.
It is recommended to disable this option for those who have library issues.
On the Poser Menu Bar - Mouse click on Scripts
select - DSON Support
select - Importer Preferences
The Preference box will open
Untick - Show Progress On Load
Close the Preference box using the X (Top Right of Box)
IsaoShi posted Mon, 25 April 2016 at 5:47 PM
vitachick posted at 11:38PM Mon, 25 April 2016 - #4266840
It's OT, but... you can dock or undock the Library panel just as you can any other panel in the Poser UI - perhaps this is not what you mean. You can also run the Library in a separate browser window, as I do (on a second screen) - is this what you are asking about? (By the way, I don't have any DSON importer problems when running the Library like this).
"If I were a shadow, I know I wouldn't like to be half of what I should be."
Mr Otsuka, the old black tomcat in Kafka on the Shore (Haruki Murakami)
WandW posted Mon, 25 April 2016 at 6:46 PM
Do you have the latest SR installed? I had this issue, and I believe this was fixed in SR1, IIRC...
dante posted Fri, 29 April 2016 at 6:49 PM
The trick with unticking "show progress on load" think resolved the problem...thanks so much adzan
versora posted Wed, 03 May 2017 at 7:33 AM
I am having a similar problem. I tried the uncheck progress bar and still doesn't work. I am trying to load real short hair for g2m. I have poser pro 11. and all programs are up to date
hborre posted Wed, 03 May 2017 at 10:18 AM
Do you have both the DAZ and Poser DSON installed?
