Forum: DAZ|Studio
Subject: "Crosstalk" Problem with G3 in DS 4.8
onimusha opened this issue on Apr 28, 2016 ยท 9 posts
onimusha posted Thu, 28 April 2016 at 9:35 PM Online Now!
This has been up on DAZ's forum for almost two days with no response. Hoping to have better luck here.
So I if load two G3's into a scene, usually starting with one, and then merging a scene which only contains another G3 figure with clothes, their morphs start to change. It looks like "crosstalk" but I'm not sure if that's what it really is as I am still a novice in DS. Using DS 4.8 in windows 8.1.
Wondering if there's a way to avoid this.
Thanks.
Medzinatar posted Thu, 28 April 2016 at 9:43 PM
do the numerical values change? does changing the position of any figure change any parameters in other figures?
onimusha posted Thu, 28 April 2016 at 10:06 PM Online Now!
Loading a new G3 figure instantly changes the values of the morphs for the figure already in the scene.
Medzinatar posted Thu, 28 April 2016 at 10:59 PM
unable to duplicate your problem in 4.8 or 4.9 Three figures cause DS to use about 3 Gb of memory. With other tasks running now, total memory usage is about 5.5 Gb. This under half capacity for 12 gb of physical memory that I have.
It would probably be best to open a support ticket at DAZ
BTW, I don't see your post in DAZ forum. What board did you post it in and what name do you use?
onimusha posted Fri, 29 April 2016 at 7:52 AM Online Now!
Nuts and Bolts...
Thanks for trying to replicate the problem... sounds very mysterious...
ldgilman posted Sun, 01 May 2016 at 11:06 AM
Sounds like a memory leak. Have you run a program like CC Cleaner (free at Downloads.com)?? It does a fabulous job of cleaning registry problems. While your there get a memory tester, it wouldn't hurt.
onimusha posted Sun, 01 May 2016 at 11:34 AM Online Now!
Great advice. Thanks!
bhoins posted Mon, 02 May 2016 at 8:51 AM
Automatically cleaning your Registry tends to break things and has little to no impact on available Memory. In many cases after you have broken something this way, the solution is to re-install Windows and start over.
Bejaymac posted Tue, 03 May 2016 at 7:31 AM
Do you use the CMS/Smart Content/Connect ?
