Subject: Uninstalling content
3dsolo opened this issue on Jun 05, 2016 · 4 posts
3dsolo posted Sun, 05 June 2016 at 2:42 PM
I installed clothing for M3 into poser 2014.. When doing so, A prompt pops up asking if I want to include an uninstaller. I chose Yes. Question is, how do I access the uninstaller to remove the Daz3d content?
Medzinatar posted Sun, 05 June 2016 at 4:36 PM
it depends on the version of the installer.
some will put them in (where content dir is)\uninstall
others put them in C:\Program Files (x86)\Common Files\DAZ
There may be other locations that are used depending on system config
Just do a search for "uninstall some_part_of_product_name exe" and it should make itself known
WandW posted Sun, 05 June 2016 at 5:28 PM
Under Windows I recall that the uninstallers could be accessed from a folder in the Start Menu's program list.
Be careful where you point the installer, as they are made for Poser 7 and earlier. DAZ hasn't used them for a couple of years, switching to .zip files. The new files can be found in the Product Library of your DAZ account, with the caveat that they are made for DAZ Studio, so the runtime folder is not in the root of the .zip file, but is in a folder called Content...
jestmart posted Tue, 07 June 2016 at 9:31 AM
The zip files a designed for DIM which only installs what is inside the Content folder.
