Subject: Can't find Kinect Capture in Poser Pro 11
agape opened this issue on Jun 16, 2016 · 32 posts
agape posted Thu, 16 June 2016 at 2:54 AM
I updated my sdk as the manual suggested and what I understood was that I could click on Window>Addons>Kinect Capture to open the window but "Kinect Capture" is not listed. I even rebooted my computer thinking that the 1.8 sdk needed that to completely be useable but I got the same results. What am I missing here?
AmbientShade posted Thu, 16 June 2016 at 6:50 AM
In Poser 11 Pro: Go to Window > Add Ons > Kinect Capture
agape posted Thu, 16 June 2016 at 11:15 AM
I guess you didn't read what I wrote. It's not there.
Medzinatar posted Thu, 16 June 2016 at 1:19 PM
I don't see it either, but I'm not running latest SR (am using 11.0.2.3.31562) and I don't have a Kinect device (or driver)
Maybe it requires one or both of those items in place before you can see it.
Boni posted Thu, 16 June 2016 at 1:39 PM
Bare with me ... I'm investigating this for you guys.
Boni
Jules53757 posted Thu, 16 June 2016 at 3:33 PM
BTW, the latest SR brings 11.0.4.32600
Ulli
Khai-J-Bach posted Thu, 16 June 2016 at 4:24 PM
Boni posted at 10:23PM Thu, 16 June 2016 - #4272660
Bare with me ...
really??
“Bear with me,” the standard expression, is a request for forbearance or patience. “Bare with me” would be an invitation to undress....... Boni! behave!
seachnasaigh posted Thu, 16 June 2016 at 6:26 PM
You must have a Kinect v1 connected or the window won't open, but you should see a prompt telling you to connect a Kinect and then restart the addon.
Medzinatar posted Thu, 16 June 2016 at 7:00 PM
There are updated Kinect drivers available from Microsoft.
KinectRuntime-v1.8-Setup.exe (Windows 7)
https://www.microsoft.com/en-us/download/confirmation.aspx?id=40277
KinectRuntime-v2.0_1409-Setup.exe (Windows 8 and above)
https://www.microsoft.com/en-us/download/confirmation.aspx?id=44559
Boni posted Thu, 16 June 2016 at 7:06 PM
Auto correct is a mean mistress. (aided with a minor case of dyslexia)
Boni
Boni posted Thu, 16 June 2016 at 9:37 PM
Was told by the guys in the know that this shouldn't happen ... best route is to make an official report and let the tech support take care of it.
Boni
agape posted Fri, 17 June 2016 at 12:02 AM
I have 11.0.4.32467. As I said in my initial post, I updated my sdk. I have the Windows Kinect and had 1.7 installed. Updated to 1.8 because I have Win 7.
Boni posted Fri, 17 June 2016 at 6:21 AM
Did that take care of it? Sorry I missed your post.
Boni
agape posted Sun, 19 June 2016 at 3:05 AM
I hooked up my MS kinect for windows, tried it on a couple of other apps I have that use it and it works fine. Fired up Poser Pro 11 and....nothing.
Richard60 posted Sun, 19 June 2016 at 10:55 AM
If it is not listed then probably your version of Poser does not think it is a Pro version, since only the Pro version has access to the Kinect. You may want to deactivate and reactivate your Poser 11 to see it that will cause the Kinect to show up. Otherwise you really need to get support help.
agape posted Sun, 19 June 2016 at 7:12 PM
Thanks, I will try that!
taiuri posted Sat, 25 June 2016 at 9:02 PM
I have the same problem, and the most strange it has all the phyton files of kinect in the C:Files Programs/Smith Micro/Poser 11/Runtime/Python/Addons/KinectCapture location, they are 10 files (7 .py and 3 .dll). But the option doesn't appear in the Program. and I have the SKD 1.8 because I have Windows 7. Please someone who can help us with this! :(
agape posted Sat, 25 June 2016 at 9:44 PM
I went to the manual and it shows some of the other options that were in the Game dev version in 2014 that should be in Poser Pro 11. Those options also do not appear in my "Poser Pro". However, some of the other options that only occur in Poser Pro are there. It's like I have half of a Poser Pro.
taiuri posted Sat, 25 June 2016 at 11:07 PM
I don't know why Poser programmers have to do everything more difficult, some options in one version but in another version doesn't have them, why not they only put all the options in all the versions? Now I have this problem, and some people here too. I contacted Smith Micro help, I hope they can give me a solution.
agape posted Fri, 01 July 2016 at 10:54 PM
Taiuri, have you gotten any help from Smith Micro yet?
taiuri posted Sat, 02 July 2016 at 12:10 PM
Yes, but they told me I need 8 installers plus the Poser installer and the Update installer, and I don't have them, probably that's the reason I don't have the option. If someone could help me send me these 8 installers, I'd thank you forever. :(
agape posted Sun, 03 July 2016 at 11:14 PM
Maybe that is my problems. I only installed the main installer, not any of the content installers. I'm not interested in the content, only the app. I think I will uninstall it and install everything. Will let you know what happens.
taiuri posted Mon, 04 July 2016 at 3:15 PM
Okay, if it works, could you send me those 8 installers I need please? Because I only have the Poser installer and the Update Installer. Thanks! Please let me know your results :)
raven posted Tue, 05 July 2016 at 3:29 PM
taiuri, use the download manager (available from here if you don't have it, http://my.smithmicro.com/poser-pro-11-updates.html ) to download the Poser installers you need. No one will send you the files.
taiuri posted Tue, 05 July 2016 at 3:31 PM
Ok. Thanks!
hdust posted Wed, 31 August 2016 at 8:38 PM
I have the same issue... updated to the latest version 11.0.5.32974 last night and have installed all the installers. I have FBX import/export, Superfly rendering but no game dev menu or kinect Ihave the Kinect python scripts in the poser folder! Has anyone found a solution?
Elnasr posted Mon, 31 December 2018 at 9:48 AM
Sorry for those that couldnt connect..open python kinect path and modify the script , change IsPoserGameDev to poser and save and restart now it shows
taiuri posted Sun, 13 January 2019 at 7:23 PM
Elnasr posted at 7:20PM Sun, 13 January 2019 - #4342791
Which one is the one I must modify? I have: ini.py, Bridge.py, Bridge2.py, filter.py, KCBv2.dll, KCBv2_32.dll, KinectCommonBridge.dll, Main.py, Quaternion.py, scale.py
Could you explain us please?
Elnasr posted Tue, 15 January 2019 at 7:05 PM
init
Elnasr posted Tue, 15 January 2019 at 7:07 PM
taiuri posted at 7:06PM Tue, 15 January 2019 - #4343590
init Where it shows " isGameDev" change it to "poser"
taiuri posted Tue, 15 January 2019 at 7:21 PM
Elnasr posted at 7:20PM Tue, 15 January 2019 - #4343685
Oh yes! It worked!! Thank you so much!! 😀
Elnasr posted Tue, 15 January 2019 at 7:25 PM
taiuri posted at 7:25PM Tue, 15 January 2019 - #4343687
You welcome !!!
