Subject: unworn clothes
xpdev opened this issue on Jul 07, 2016 ยท 13 posts
xpdev posted Thu, 07 July 2016 at 9:10 AM
Hi
i have a lot of problems when i need to build a scene with clothes not on a figure.
For example, pants, shirt ecc. on a bed or on a chair ecc.
There are ready props or i need to use dynamic clothes ?
many thanks
Poser Pro 2014 SR 1 on Windows 7 64 bit
I use IDL, Gamma Correction and EZSkin for all final renders.
tonyvilters posted Thu, 07 July 2016 at 9:41 AM
Depends on what you want to do.
Hundreds of options but all depend on what exactly you want to do.
hflam posted Thu, 07 July 2016 at 12:46 PM
Turn the zScale of body to 15% or lower, You can get a quick flat cloth.
Boni posted Thu, 07 July 2016 at 2:57 PM
This was quick ... just on the floor. 4 dynamic articles of clothing. 4 simullations in turn, each colliding against self, ground and all others. Took 5 minutes.
And 2 with a chair (shirt and dress) ... less than five minutes to set up and render.
Boni
xpdev posted Fri, 08 July 2016 at 1:04 AM
Hi Boni
your way is the same i use, but how you can see under the arrows, you have the same problem that i have on my dynamic clothes.
xpdev posted Fri, 08 July 2016 at 1:58 AM
This is what appens to my dynamic clothes. Render is on full resolution
Any idea ?
lookoo posted Fri, 08 July 2016 at 3:42 AM
Check in the dynamic cloth menu "self-collision" and increase the collision offset and collision offset, maybe to 2.000 each.
xpdev posted Fri, 08 July 2016 at 4:01 AM
" increase the collision offset and collision offset ..."
The same thing or it's a mistake ?
Boni posted Fri, 08 July 2016 at 10:53 AM
I knew mine wasn't perfect, they were quick and dirty examples that needed fine tuned. It was a starting point. I really like the added tips!
Boni
ElZagna posted Fri, 08 July 2016 at 8:37 PM
xpdev posted at 8:26PM Fri, 08 July 2016 - #4275007
Collision offset and collision depth, I'm sure.
Also you might try _smoothing _the items with the morphing tool. Actually your clothes are pretty smooth already, but if they come out like Boni's, a little smoothing would help.
OS: Windows 10 64-bit, Poser: 10
lookoo posted Sat, 09 July 2016 at 4:13 AM
Yes, collision offset and collision depth, of course! Did it help?
quietrob posted Wed, 13 July 2016 at 11:07 PM
This is something I think should be made more prominent. I was rendering a boy's room and thought, "it's way too perfect. It needs be messier!" I haven't done dynamic very often but this is another reason to learn.
(Sorry about the messy room, Mom!)
NolosQuinn posted Thu, 14 July 2016 at 8:58 AM
Try VWD Cloth & Hair for Poser, available here at Renderosity. There is a lite and full version. Yes, it costs, but worth it.
'I'm paying for this movie. I want guns'
