estherau opened this issue on Jul 31, 2016 ยท 10 posts
estherau posted Sun, 31 July 2016 at 9:40 PM
special software. Is there a good tutorial somewhere please?
adzan posted Mon, 01 August 2016 at 6:16 AM
Hi. Here's a quick steps to making the Injection Morph with Poser 11 Pro (the export injection morph is only in the Pro version)
Load your morph
Select the figure
Choose - File > Export > Morph Injection
The Select objects box will open with all items selected
Press the Select None Box
Then Choose the morph you want to save.
If the morph has a master dial on the BODY it will automatically select all the separate morphs that relate to the master dial (ie a Full Body Morphs)
Click OK
The Save Morph to Injection File window will open
Choose a folder and save the morph
Save your scene...
To test the morph, start a new scene, load the character without the morph, apply the morph to make sure it works.
ssgbryan posted Tue, 02 August 2016 at 1:09 AM
Ch. 32 - Modifying Figures and Props - Saving Morph Injection Poses; Pg 784 in the User's manual.
Follow that up with
Copying Morphs Between Figures - to put that morph into your clothing; Pg 785.
estherau posted Tue, 02 August 2016 at 5:11 AM
thanks. I also see there is the option to export the morph for conformers so I presume that makes a clothing pose.
Lyrra posted Wed, 03 August 2016 at 9:26 PM
note - Poser can get confused on export. all morph parts need to be visible for export and have the same name. DAZ's morphs have different names for the Body dial and other dials and therefor do not always export
Conversely, all channels being injected to need to be visible or poser once again gets confused.This becomes an issue if you have a morph with bodypart scaling attached, as DAZ hid the scale dials on bodyparts.
Also a morph exported in this way can be loaded and used fine in poser to, and I believe poser 9 as well. I don't know about earlier versions, but in theory any version of poser that accepts PMD morphs should do fine.
LM
estherau posted Fri, 05 August 2016 at 3:57 AM
Thanks everyone!
JAFO posted Wed, 10 August 2016 at 4:19 AM
OK I'm confused... So the morph injection is basically just an easier refined version of the old export and load full body morph, and not a way to inject a complete character(dials and settings ) into a basic/blank figure??
Y'all have a great day.
estherau posted Wed, 10 August 2016 at 5:04 AM
The Lyrra morph is a character or just child proportions.U get a few dials to play with.
TeamSchmidt posted Wed, 20 November 2019 at 12:08 PM
Are morph injection files made this way in PP 11 able to be sold? Like do they contain copyrighted morph data if you use the V4 ++ dial morphs to create a custom morph for example?
estherau posted Wed, 20 November 2019 at 4:31 PM
I presume they contain data so the answer would probably be no, but someone who makes morphs will be able to answer better than me. Love esther
