Forum: New Poser Users Help
Subject: Rendering Problem
Sharaya opened this issue on Aug 06, 2016 ยท 5 posts
Sharaya posted Sat, 06 August 2016 at 9:07 PM
Hello. I'm using Poser Pro 11 with Firefly and a V4 character called Titania with one Area Light, rendering at 2000x1500. Could someone tell me why the black lines appear on the neck and under the arm, as well as other places? I... think... all of the render settings are the default settings except maybe it's set to smooth polygons.
Anthanasius posted Sun, 07 August 2016 at 5:49 AM
Hi !
I think it's your shader.
Génération mobiles Le Forum / Le Site
donnena posted Sun, 07 August 2016 at 1:50 PM
What happens if you try with another skin?
that effect is generally because the displacement is too strong.
Andy!
Sharaya posted Sun, 07 August 2016 at 6:36 PM
I did try a different texture and had the same issue. I don't know enough about shaders to experiment with that. Like, I don't know if the shader can be replaced with another one or if it has settings, and don't know where to find the shader or settings. I did find a setting for displacement and it just had a question map by it with apparently no displacement map. The good news is after starting over and rebuilding the character from the default Victoria 4, the rebuilt character doesn't have this issue. So I thank you both for trying to help me, and one way or another the problem was solved. I just may never know what went wrong...
donnena posted Sun, 07 August 2016 at 9:44 PM
I'm glad you have a fix if not an answer!!!
Happy rendering!
Andy!
