Kixum opened this issue on Aug 14, 2016 · 15 posts
Kixum posted Sun, 14 August 2016 at 12:30 AM
I onto my next large project. Some of you know of a wonderful artist named John Harris. I have re-imagined one of his paintings call MASS the building of FTL1. I was doing a little more research on him when I cam across a painting he did for a book cover titled Spindrift.
Re-working a painting is an interesting process and artform in itself. I love this image so I am giving it a shot. As usual per previous projects I have worked on, I will post in this thread as I make progress.
-Kix
Kixum posted Sun, 14 August 2016 at 12:32 AM
I will not post an image of the original painting in this thread given I don't know what kind of copyright issues may exist. However, if you look at my progress after the first day, I'm sure you can find the original reference. The first day of working on a project like this is very difficult. The primary shapes need to be established as well as a camera position, focal length, and initial geometric sizes and depth. It's not easy to get all these things to come together!
-Kix
Here is my second days progress.
-Kix
Kixum posted Sun, 14 August 2016 at 12:34 AM
And here is the third day of work. As can be seen, I have decided to work on the main supporting pylons first. Soon, I will be done with that part and will move on to the ship. It's working!
-Kix
radioham posted Sun, 14 August 2016 at 8:09 AM
Looking good it is not the easy to do any thing in this program but it can use props from both Poser and Studio and give good renders keep it going look forward to see the image when it is finish
ShawnDriscoll posted Sun, 14 August 2016 at 9:43 AM
My favorite massive artist.
DUDU.car posted Sun, 14 August 2016 at 2:20 PM
radioham posted at 2:19PM Sun, 14 August 2016 - #4279895
To use an evolved program, one needs a minimum of intelligence, DAZ Studio is made for the other category of users… Nice work Kixum !
ShawnDriscoll posted Sun, 14 August 2016 at 5:23 PM
DUDU.car posted at 2:15PM Sun, 14 August 2016 - #4279925
Carrara modeling is not for everyone. That is why Eovia brought in Amapi 7, back in the day. And Hexagon would later come from Amapi. 3D modeling in Hexagon comes more naturally for some artists. Programs like modo have made that simple modeling style much more complicated at the other end of the spectrum. Carrara and 3DCrafter are at one end, while modo and Lightwave are at the other. Simple 3D modelers like Hexagon and Silo are in the middle of the spectrum. 3D-Coat is closer to modo than it is to Carrara.
Kixum posted Mon, 15 August 2016 at 12:13 AM
Carrara modeling is a little bit unique. I have been doing it for a long time and I use it basically because it's something I know and I can get results from it.
I have now basically put in all of the fundamental structures. Now it's a matter of texture and small details. I am going to have to stare at this thing for a few days to fill in the blanks.
-Kix
Kixum posted Mon, 15 August 2016 at 12:15 AM
By the way, thanks for all the feedback! Carrara is used a lot for rendering content but I render only my own content I build (probably one of the very few).
-Kix
radioham posted Mon, 15 August 2016 at 5:02 AM
At this point in time I am doing my best to learn Blender and 3D Max
MarkBremmer posted Mon, 15 August 2016 at 5:38 PM
Looking forward to the progress!
Kixum posted Sun, 21 August 2016 at 1:54 AM
Here is day 5. The changes are subtle but make a difference. Hand rails, more surface details, and some dialing in some of the textures. Soon, I am going to give up and call it!
-Kix
davidstoolie posted Sun, 21 August 2016 at 1:00 PM
radioham posted at 12:52PM Sun, 21 August 2016 - #4279980
Well if you can afford 3ds Max, then you have one of the best modelling software right there, and very lucky! Blender is also a great modelling software. Have a look at Luxxeon tutorials, and you can make comparison between the two. He does objects in 3ds Max and then the same in Blender.
Kixum, very good job!
Kixum posted Sun, 21 August 2016 at 8:32 PM
Thanks again for all the comments. I have decided to call it and here's where I ended up. You can also find the same render in the gallery.
-Kix
