Subject: OK OK OK OK....whats up with poser pro pack
Deal opened this issue on May 08, 2001 ยท 4 posts
Deal posted Tue, 08 May 2001 at 9:48 PM
ALOT of old PZ3s that I open up in Pro Pack are missing polygons. Why? Is there a way to fix it.. Also Some PZ3s that have alot props in them make all the props invisible ..I have to go to each one and make it visible....Very frustrating. it also seems to run slower than poser4. HELP. TIA
JKeller posted Tue, 08 May 2001 at 11:34 PM
This has to do with a change they made in the way the Pro Pack reads geometries (their gonna change it back with the next patch).
Open the PZ3 in a text editor. Your going to find that the geometry of some of your props and other things have been embedded into the PZ3 file (it doesn't reference the original .obj anymore). These geometries are seperated into groups by lines that start with the letter 'g'. Generally group labels look like this: 'g lForeArm', 'g hip', 'g rFoot', etc. Sometimes you will find (generally if the grouping tool has been used) group lables that are just a 'g' with no name after it. Poser could read these empty 'g' lines fine, but this is where Poser Pro Pack screws up and doesn't read any of the 'f' lines (faces) that fall under that empty lable.
Okay, enough theory. Here's how you fix it:
With your PZ3 open in a text editor do a search for 'g'. Whenever you find one of these un-labled g lines, give it a lable. It can be anything... 'g blah', 'g blank', 'g unknown', whatever. SAVE AS the file (just to be safe) and you should be able to open it up in Poser Pro with no holes.
Hope this helps.
nitreug posted Wed, 09 May 2001 at 12:21 AM
me too I am waiting for the patch but it takes a LONG LONG LONg time to act on a patch. I basically do not use it until they fix their bugs. I put Pro PAck on a separate drive and since two months, i only use three times. User guide is very poor. Claude
Deal posted Wed, 09 May 2001 at 8:46 AM
Thanks for the help, When is the patch supposed to come out?
