mdbruffy opened this issue on Sep 04, 2016 ยท 7 posts
mdbruffy posted Sun, 04 September 2016 at 12:52 PM
Does anyone know of a shirt for Micheal 4 that has the same kind of open morphs that this safari shirt for Micheal 3 has? Wardrobe Wizard doesn't copy morphs. I'm using Poser Pro 11.
EClark1894 posted Sun, 04 September 2016 at 1:02 PM
Have you tried to use PP11's Copy Morph command under the Figure Menu to copy from the shirt that has the morph to the one that doesn't?
mdbruffy posted Sun, 04 September 2016 at 1:12 PM
I tried. It won't acknowledge the correct shirt. If I load the original and then the conversion, the process will only acknowledge the conversion. Same if I load the conversion first.It won't copy from the original shirt. And if I delete the conversion, it won't acknowledge the original that's still on the screen.
raven posted Sun, 04 September 2016 at 2:25 PM
Wardrobe Wizard should convert the morphs, this is the M3 safari shirt converted to M4 in P11Pro. The only problem I had was with the shirt buttons, they didn't morph with the untuck morph, so I made them invisible.
mdbruffy posted Sun, 04 September 2016 at 2:31 PM
The untucked morph was what I wanted. I took a long shot and conformed the M3 shirt- and it was an almost exact fit to M4. I had to work with the sleeves and arms, But I finally got something I could use:
raven posted Sun, 04 September 2016 at 2:43 PM
That looks fine. A quick touch of morph brush could hide the small parts of M4's arms if necessary too.
mdbruffy posted Sun, 04 September 2016 at 2:46 PM
