Subject: V4 Morphs ++
vampchild opened this issue on Sep 05, 2016 ยท 4 posts
vampchild posted Mon, 05 September 2016 at 8:31 AM
Need a little help please. I got a new computer with windows 10-64 and had to load Poser 10. I got everything loaded except V4 Morphs ++. I loaded the morphs manualy because the auto load don't work anymore (get some strange line about a missing daz thing or other) so when I try to load the morphs to V4- I get a window asking about a V4-morphs All which I cannot find in my runtime anywhere. I loaded every thing that was in the files.What did I miss? HELP!
Beware-The Smoking Man Still Lives!
3DFineries posted Mon, 05 September 2016 at 8:42 AM
Did you initialize the morphs? V4 has to be installed in a specific order V4, other morphs like Aiko, etc, and THEN Morphs++ and you MUST run the initialize scripts each time. So I would uninstall everything you installed, then reinstall as above making sure to initialize any time it asks. If it's not that, then I'm at a loss.
Hope it helps.
Have a creative day!
My Lil' Store
RHaseltine posted Mon, 05 September 2016 at 2:04 PM
That is, run RuntimeLibraries!DAZDzCreateExPFiles-v4.bat when you install an ExP morph expansion. If you installed manually you won't have the desktop shortcut. If you are using the Bitrock (executable) installers then you may well get an error about the pzs link file - that just added a link to the Daz store to the Poser help menu (I think), and doesn't matter - however the old installers really are old so it's a good idea to replace them - for simplicity with the Install manager though manual install of the zips is fine if you know what you are doing. Do make sure you are not placing the content in the application folder, though.
vampchild posted Tue, 06 September 2016 at 6:19 AM
Thanks for the help. I reloaded the morphs and restarted the computer and everything worked. The newer Posers don't seem as easy to load daz characters as the older Posers.
