Kinder-1 opened this issue on Sep 09, 2016 ยท 15 posts
Kinder-1 posted Fri, 09 September 2016 at 10:00 AM
Hi, I have Poser Pro 2012. I recently bought Lyrra's M4 Child Dial from the Renderosity store. In order to use this product I need to unhide the parameter dial for M4 but then learned that my version of Poser does not have this facility. After some research I downloaded a free python script from Dimension 3D to rectify this. However when I try to run the script Poser crashes. Any advice welcome.
donnena posted Fri, 09 September 2016 at 10:07 AM
Have you contacted Dimension 3D?
Andy!
Kinder-1 posted Fri, 09 September 2016 at 10:18 AM
Sorry I realise that I have described the problem inaccurately. When I run the script get a pop up of two columns of dials - one says hide the other show. The actual parameter dial on the figure is not altered. It is when I try to inject the product from Lyrra that Poser crashes.
donnena posted Fri, 09 September 2016 at 10:26 AM
ok... I thought the pro versions of didn't need the script, but if you can give me the link to the freebie, I'll download everything and test for you... It will be later in the day before I can get to this, due to existing work load!
Andy!
Kinder-1 posted Fri, 09 September 2016 at 11:06 AM
http://d3d.sesseler.de/index.php?software=poserpython&product=unhide_dials
Kinder-1 posted Fri, 09 September 2016 at 12:58 PM
Thanks donnena for your help on this. The M4 Child Dial read me said that you needed to expand the parameter dial options to reveal the hidden values by clicking on the white arrow or right clicking before loading the product. Otherwise it wouldn't work. When I did this the unhide option was absent. I subsequently googled the issue and found a Poser forum on Daz where the same problem had been discussed. Apparently some versions of Poser do have the unhide option (including some old ones) but some don't and that includes Pro 2012. This Daz forum suggested downloading the script and gave links which is what I did. As I say when I run the script I get the two columns as shown in the freebie description but I'm not sure what to do next. The parameter dials do not show the hidden values.
donnena posted Wed, 14 September 2016 at 9:40 PM
Hello!
I'm not ignoring you! But tomorrow looks good for me to be able to carve out a couple consecutive hours to look into this! Please bear with me!!
Andy!
Andy!
Kinder-1 posted Sun, 18 September 2016 at 2:05 PM
Hi Andy Basically I just want to be able to use Lyrra's M4 Child Dial in Poser Pro 2012 - so any solution is welcome.
donnena posted Sun, 18 September 2016 at 3:33 PM
Hello!
I understand!!! I am in a huge puddle of guilt here, because I am swamped and can't carve out the time to load the python and try to help you! Have you contacted Lyyra? She's really a very sweet lady!
I know this is no help, but you're on my To Do list. I do need to know if you're version of PP 2012 is up to date? Do you have all the released patches for it?
Andy. Guilty!
Andy!
Kinder-1 posted Wed, 12 October 2016 at 4:40 AM
Hi Andy, Sorry for delay - I've been on holiday. I did update my Poser Pro 2012 but my computer died last year and when I installed PP 2012 from my disk onto my new computer I have never got round to installing any updates. Should I do this? If so how do I do it as I've forgotten.
thanks John
donnena posted Wed, 12 October 2016 at 5:04 PM
Hi ya!
Me too! We went to Hawaii!!
yes, please!! Ha!!! Took me over 30 minutes but I found this --> http://my.smithmicro.com/poser-pro-2012-updates.html Good luck!!!
Please let me know if this doesn't help!!!
Andy!
Andy!
Kinder-1 posted Thu, 13 October 2016 at 2:36 AM
Hi Andy - sorry to be a pain. I've found the updates (thank you). There seems to be 2 for my version of poser - SR3.1 and SR3.2 - Do I need to install both or does 3.2 already include 3.1
Thanks
Richard60 posted Thu, 13 October 2016 at 6:15 PM
All you need is the latest update.
Kinder-1 posted Mon, 24 October 2016 at 7:29 AM
Hi Andy, I've installed the SR3.2 update but this hasn't resolved the problem. There is still no unhide option when I click on the arrow by the parameter dial. Also when I run the script I still just get a pop up list which does not do anything. However I've just bought the ultimate teenager set from Renderosity and this is working well so I now find I do not really need Lyrra's product any more. Thanks for your efforts and I'm happy that you've prompted me to install the update so my Poser Pro is working better and this has at least achieved something.
Miss B posted Mon, 24 October 2016 at 9:05 PM
Hi Kinder, when you get the popup list, do you select the items in the Show list you want to unhide, as that's how they get unhidden. You have to choose which items you want unhidden, as there might be more than just the one you're interested in, and then click on the Show button at the top of the list. Then when you look in the Parameters tab, the hidden files should show up under the "hidden" list.
I use D3D's script fairly often, and have not had any problems with it.
_______________
