Subject: Draping in Poser Pro 11
arrow1 opened this issue on Sep 23, 2016 ยท 3 posts
arrow1 posted Fri, 23 September 2016 at 10:23 PM
I have a 30 frame animation of a girl riding a bicycle.It is looped.With Dynamic Clothing is it necessary to drape none or all 30 frames of the simulation? I have watched a few tutorials on this but it is not explained properly! Cheers
Custom built computer 128 gigs RAM,4 Terabyte hard drive, NVIDIA RTX 4060 TI 16 GIG Gig,12 TH Generation Intel i9, Dual LG Screens, 0/S Windows 11, networked to a Special 12th Generation intel I9, RTX 3060 12 Gig, Windows 11,64 gigs RAM, Dual Phillips Screens, 2 Terabyte SSD Hard Drive plus 1 Terabyte Hard Drive,3rd Computer intel i7,128 gigs ram, Graphics Card NVIDIA RTX 3060 Gig,1 Terabyte Hard Drive, OS Windows 11 64 Bit Dual Samsung Syncmaster 226bw Screens.Plus INFINITY Laptop 64 Bit,64 gigs RAM.Intel i9 chip.Windows 11 Pro and Ultimate. 4 x 2 Terrabyte Hard Drives and 2 x 2 Terrabyte external USB Hard drives. All Posers from 4 to Poser 2010 and 2012, 2014. Poser 11 and 12, 13, Hexagon 2.5 64 Bit, Carrara 8.5 Pro 64 bit, Adobe Photoshop CS4 Creative Production Suite. Adobe Photoshop CC 2024, Vue 10 and 10.5 Infinite Vue 11 14.5 Infinite plus Vue 15 and 16 Infinite, Vue 2023 and 2024, Plant Catologue, DAZ Studio 4.23, iClone 7 with 3DXchange and Character Creator 3, Nikon D3 Camera with several lenses.  Nikon Z 6 ii and Z5. 180-600mm lens, 24-70 mm lens with adapter.Just added 2x 2 Terrabyte portable hard drives.
3D-Mobster posted Sat, 24 September 2016 at 2:40 AM
Its a matter of choice i think, at least for me, I would drape the cloth if its way off in fitting the character or if you have an animation where the cloth is not linked to the interaction object. You have to remember that drape is done before the actual simulation is calculated and are not stored within the simulation, so if you were to cancel the calculation during the drape the cloth would return to its default starting position. Here is a small test to show it.
At the top is the actual scene.
Next image shows what the first frame using drape looks like.
Then the final result for both a simulation using drape and one that is not. As you can see the different is not that huge, however if the fish for instant were swimming forward from frame 1, using drape would allow the cloth to interact with the fish before it actually moves and therefore move with it during the animation.
So in such case using drape would be a good idea, otherwise the fish might have moved before the cloth reaches it. If you are simulating a piece of cloth for a human it would normally be linked to it and therefore follow along with it, so it would probably not make a huge different whether you drape first or not, at least I wouldn't bother doing it in such case, because the actual simulation would make it look realistic enough in end anyway.
Boni posted Sat, 24 September 2016 at 7:48 AM
Are you using a fan in your sim for the air movement on the skirt as the bicycle moves? Oh, and did you get that motion blur to work on the wheels?
Boni
