3doutlaw opened this issue on Oct 20, 2016 ยท 6 posts
3doutlaw posted Thu, 20 October 2016 at 7:52 AM
Is it possible in VWD to animate a thick object? For example, if I modeled a quilt as a blanket that had some thickness to it, can I drape it, without losing the thickness? I think there may be a solution in this video, https://www.youtube.com/watch?v=zggjPFzI6XQ, using the chain, since the chain links must have some thickness, and they do not flatten when the simulation is run...but I can only watch and not understand what he is saying.
Thanks!
VirtualWorldDynamics posted Thu, 20 October 2016 at 2:08 PM
Hello 3doutlaw,
Sorry for these videos in French. I promise you to make the new videos in English even if my accent will be horrible. I think this solution will help more.
If you want to simulate a blanket with a thickness, I think you can generate two meshed planes separated by a small distance. Then you can rigidify these planes as you want and then, you can use a rigidification by neighborhood using a distance that will only link the vertices of the two planes, 2 by 2 with a very low value (0.001 for instance).
The simulation will simulate the 2 planes like one but will keep the distance between the two planes.
Tell me your results, I will make some tests myself.
____________________________________________
Follow me on Twitter : @VWDynamics
Watch demo videos on Youtube
3doutlaw posted Thu, 20 October 2016 at 3:39 PM
OK, I am new to using this, but I will try to do something like that. The Quilt/Blanket was just to give the idea.
Ideally what I am after is to use dynamics on a hair that has thickness, like these...so they don't flatten out when a simulation is run
http://www.sharecg.com/v/81780/related/11/Poser/bob-Hair-for-STAR%21-POSER#
VirtualWorldDynamics posted Fri, 21 October 2016 at 11:17 AM
For me, there is no problem. One of the videos have been made with hair which has a mesh like the one you gave me as link.
I will tell you the name of this hair.
I you want to try, it is necessary to use a rigidification by neighborhood but with high value (low rigidification), perhaps 0.3.
3doutlaw posted Fri, 21 October 2016 at 11:30 AM
Do you have the specific link to the video, so I can tell which video it is?
VirtualWorldDynamics posted Fri, 21 October 2016 at 12:10 PM
This hair is "Melitte hair". You have to look at the mesh to see its structure.
The video link is : https://www.youtube.com/watch?v=NUOEuCBLC6Y
