SamTherapy opened this issue on Nov 11, 2016 ยท 33 posts
SamTherapy posted Fri, 11 November 2016 at 4:14 PM
Try as I may, I cannot get glass to look right. I'm really getting annoyed because even BB's beer glass shader looks wrong to me.
I made a simple empty glass, UV mapped and imported to Poser, applied the shader but when rendered, the glass looks really dark. I'm using Poser Pro 2012, IDL and a single infinite to mimic the sun. There's a ground plane and a sky dome, so there's something for the shader to react to.
Just to show what I mean, here's a render.
LaurieA posted Fri, 11 November 2016 at 5:00 PM
if you have it, try loading BBs envirosphere and put an image on it and then render the glass again. You can turn off "Visible in Camera" if you don't want to see it in the background, but it will still reflect onto the glass. A screenie of the material room wouldn't hurt either ;). I'm assuming you're talking Firefly. If Superfly, I can't help you but maybe someone else can. :)
LPR001 posted Fri, 11 November 2016 at 5:26 PM
LaurieA is right it is probably reflecting the dark side of the dome with nothing to reflect PP2012 would be Firefly
- Johnny G
"Try animation to get things moving"
lpr001@renderosity.com
SamTherapy posted Fri, 11 November 2016 at 5:34 PM
Still don't see how but I'm giving it a go. Anyhow, this is the Material for BB's glass.
LaurieA posted Fri, 11 November 2016 at 5:36 PM
I'm sorry...I missed the 2012 part ;). Need new glasses ;P
LPR001 posted Fri, 11 November 2016 at 5:40 PM
Just tested it in PP2014 and got same result Sam although I used a beer bottle looking glass and ended up with the much darker grey. Then added Terradome and there it was transparent glass with no issue :-)
- Johnny G
LaurieA posted Fri, 11 November 2016 at 5:47 PM
I think for fun I'm going to import a copy of my whiskey glass with the ice in it into Poser and see what I can do with firefly shaders in it ;). Haven't done that in awhile. LOL.
SamTherapy posted Fri, 11 November 2016 at 5:51 PM
Hmmm... used BB's Envirosphere and got the same as before. Maybe I should boost the Ambient.
Nope still looks dark.
LPR001 posted Fri, 11 November 2016 at 5:56 PM
That was weird Laurie I better let the boss know I just quoted you and it changed you comment.
- Johnny G
LPR001 posted Fri, 11 November 2016 at 5:57 PM
*Your
- Johnny G
SamTherapy posted Fri, 11 November 2016 at 6:07 PM
Gettin roundly hacked off with this. I have no idea what to do and everything looks a load of testicular material.
RedPhantom posted Fri, 11 November 2016 at 6:33 PM Site Admin
Here's another glass that BB posted. I use it when the one you're using doesn't work. Sometimes It's not anything you've done, but the object itself.
SamTherapy posted Fri, 11 November 2016 at 6:47 PM
SamTherapy posted Fri, 11 November 2016 at 6:51 PM
Definitely an improvement, although the inside of the glass, where it shows above the rim, appears black.
LaurieA posted Fri, 11 November 2016 at 6:52 PM
You have at least 4 reflection bounces in your render settings??
LaurieA posted Fri, 11 November 2016 at 6:53 PM
Try a fresnel node coming out of alt diffuse and kt microfacet coming out of alt specular. That's my recipe for glass. LOL Of course regular diffuse and spec should be at 0. It's clear. I'm rendering a glass with liquid right now and I can see the liquid on the inside from the outside ;).
SamTherapy posted Fri, 11 November 2016 at 6:54 PM
Erm, I forgot to set transparency. And silly bugger that I am, me bounces were set to 2. Oh dearie me, sorry guys. Let me try again and report back.
LaurieA posted Fri, 11 November 2016 at 6:54 PM
you don't need transparency
LaurieA posted Fri, 11 November 2016 at 6:56 PM
about as simple as you can get, but then I'm a simple minded person ;)
LaurieA posted Fri, 11 November 2016 at 7:04 PM
LPR001 posted at 8:04PM Fri, 11 November 2016 - #4289749
Changed it to what? LOL
SamTherapy posted Fri, 11 November 2016 at 7:06 PM
Right... the shader RedPhantom posted still renders the same with 4 bounces and transparency.
SamTherapy posted Fri, 11 November 2016 at 7:18 PM
BB's original shader works just dandy with 4 bounces. I am a complete and utter fuckwit.
Had a meeting with my son's teacher earlier this week. She tells me he has all the signs of "highly gifted to genius" and all the necessary skills and attitude to see him right through his education. Obviously not from his dad.
SamTherapy posted Fri, 11 November 2016 at 7:29 PM
Thanks, all. Your patience with my stupidity is much appreciated.
LaurieA posted Fri, 11 November 2016 at 7:35 PM
Hahaha....if you think I've never forgot the reflection bounces and scratched my head and fiddled with a shader for an hour before it hit me, you'd be wrong. LOL
SamTherapy posted Fri, 11 November 2016 at 9:40 PM
LaurieA posted at 3:39AM Sat, 12 November 2016 - #4289769
I'll blame it on me recent pneumonia, which is still kicking my ass.
Boni posted Sat, 12 November 2016 at 7:22 AM
Well Sam, show us the final render. We want to see what it is suppose to look like.
Boni
SamTherapy posted Sat, 12 November 2016 at 9:05 AM
Nowt special, just a test for some bottles I'm making.
Miss B posted Sat, 12 November 2016 at 12:32 PM
bagginsbill posted Sun, 13 November 2016 at 6:57 AM
I have written this before but I'm sure it's lost in the mists of time so here it is again.
You need at least six bounces to make a bottle with thickness show all the important features you expect, and not reach a black nothingness.
For most people there is NO reason to EVER set the bounces lower than six. FireFly (unlike SuperFly) doesn't use bounces unless it needs to, so using a lower, inferior setting doesn't do you any good, but using a higher, superior setting does, especially when you go a couple years and can't remember rule 1.
bagginsbill posted Sun, 13 November 2016 at 6:59 AM
Also, have you not read my sig? I may not be aware of replies if you post them here. If you post them at the SM site I always see them.
bagginsbill posted Sun, 13 November 2016 at 7:01 AM
And in case anybody deigns to suggest I turn on the reply notification checkbox, FFS it's always checked and I'm not getting reply notifications but I ALWAYS get notifications of other kinds, so it's not my email, either. For example, it was an email that let me know Sam created this thread, and I came to look because I respect Sam.
SamTherapy posted Sun, 13 November 2016 at 7:08 AM
Thanks, BB. I have it sorted now. :D I now have bounces set to 6 as my default.
I'm sure you have posted about this in the past but I lost a lot of stuff when I changed computers. Many of my saved bookmarks didn't import and several forum changes didn't seem to help, either. Still, ta very much for the reminder. It's now committed to memory (or at least, what passes for memory round here).
bagginsbill posted Sun, 13 November 2016 at 2:54 PM
No, forum changes do not help. As I warned, I did not get a notification that you responded.
That's an invitation to stop responding to me here. I won't keep polling the thread by hand. I don't have time.
