meltz opened this issue on Nov 14, 2016 · 5 posts
meltz posted Mon, 14 November 2016 at 8:16 AM
I have been a use of poser pro 2012 for years and have alot of content. I am interested in trying out the new daz studio. How do i go about transfering my content from poser pro 2012 into the daz studio? I would hate not to be able to use all of my models =-) Thanks for the help in advance
vitachick posted Mon, 14 November 2016 at 8:41 AM
This is how I did it
Win10 Poser 2014/Poser 11 Daz3D
donnena posted Mon, 14 November 2016 at 9:12 AM
Or you can just map your Poser Runtime to DS... Right click in the empty space below My DAZ 3D Library, Choose Add a base directory. Navigate to your Poser Runtime.
Happy Rendering!
Andy!
hborre posted Mon, 14 November 2016 at 11:25 AM
Be aware that some content will not port over easily. Also, depending how ancient is your collection and whether purchases/freebies were downloaded from DAZ3D, there may exist exclusive DAZStudio files which will need to be installed rather then using Poser files. Further investigation is necessary.
wheatpenny posted Mon, 14 November 2016 at 11:56 AM Site Admin
The easiest way if you have a lot of runtimes, is to go to the content pane and click on the icon to the upper right which looks like 4 lines and an arrow. From the dropdown select "search Hard drives for files". A dialog will come up. select the hard drive that your runtimes are on, then on the next dialog select "do search. When it finishes searching, uncheck any runtimes that you don't want to load in Daz. (if you want to use all of them then leave all the boxes checked), then select "accept".
Jeff
Renderosity Senior Moderator
Hablo español
Ich spreche Deutsch
Je parle français
Mi parolas Esperanton. Ĉu vi?
