SamTherapy opened this issue on Nov 17, 2016 ยท 9 posts
SamTherapy posted Thu, 17 November 2016 at 12:40 PM
Trying to convert the M2 suit coat to M3 gives the following error:
Error!
Traceback (most recent call last):
File "C:UsersPaulPoser Pro 2012RuntimePythonposerScriptsPhilCWardrobe Wizard P9m0.py", line 11, in
Any ideas?
Poser Pro 2012, Win 7 Pro 64 bit.
Boni posted Thu, 17 November 2016 at 12:43 PM
I suggest you contact PhilC directly, he is always willing to help.
Boni
PhilC posted Thu, 17 November 2016 at 1:00 PM
Usually get this when a resource file has an anomaly in it. Could even just be a bad ascii character or line ending. Very difficult to track down. I'll be happy to look over it but I would need all the files which may be a problem because many of them are not allowed to be redistributed.
SamTherapy posted Thu, 17 November 2016 at 2:13 PM
PhilC posted Thu, 17 November 2016 at 4:08 PM
Try checking the log, it may help give an indication. This might be in:- C:UsersPublicDocumentsPoser Pro 2012 ContentRuntimePythonposerScriptsPhilCWardrobe Wizard P9
or similar, or search PC for "ww.log"
SamTherapy posted Thu, 17 November 2016 at 4:18 PM
Thanks, mate. Just had an idea, may or may not be relevant...
My old copy of WW is still in an external Runtime, would that cause a conflict, or other error? Not using it though; I'm using the one built into PP2012.
SamTherapy posted Thu, 17 November 2016 at 4:29 PM
Here it is. I haven't a Scooby what it's telling me, apart from there's an error. :)
Timestamp: Thu Nov 17 18:36:51 2016 pathname C:UsersPaulPoser Pro 2012RuntimePythonposerScriptsPhilCWardrobe Wizard P9
singleSelectPATH ['C:\Users\Paul\Poser Pro 2012\Runtime\Libraries\Character\M2\M2 Clothes\Basic clothes\Suit Coat.cr2'] batchSelectPATH C:UsersPaulPoser Pro 2012RuntimeLibrariesCharacterM2M2 ClothesBasic clothes outputfolder C:UsersPaulPoser Pro 2012 fromtype 0 hires 1 forceanalysis 0 keepmorphs 1 regroup 1 fixpopthru 0 proponly 0 breastpuff 0 looseness 10 fromfig M2 tofig [u'M3'] bodymorphs 1 flared 0 closeFit 1 RegroupHarder 0 MatDials 0 copyWeightmaps 0
Converting the following 1 files C:UsersPaulPoser Pro 2012RuntimeLibrariesCharacterM2M2 ClothesBasic clothesSuit Coat.cr2
Progress: 33% done. Elapsed time: 0.00 mins. Time remaining: 0.00 mins Hi res analysis ZClothing_MilMan_blSuitCoat.dat being created, one moment please... -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-= Error!
PhilC posted Thu, 17 November 2016 at 4:34 PM
With Poser closed, try finding ZClothing_MilMan_blSuitCoat.dat Delete it. Open Poser and try again.
Its a long shot but worth a try.
Also try opening the original coat's OBJ file in a text editor and see if you can find any anomalies. Usually in the form of bad characters, Chinese? I've seen them slip into the start of the "f" lines section.
SamTherapy posted Thu, 17 November 2016 at 4:52 PM
Will do. Meantime, I tried converting the P4 Male Tuxedo to M3 and got exactly the same error. Makes me think it's not a problem with the OBJ. I'll still take a look, as you suggest.
