Forum: Poser 11 / Poser Pro 11 OFFICIAL Technical
Subject: Installed Daz content doesn't show up in Poser 11 library.
anniemation opened this issue on Nov 17, 2016 ยท 8 posts
anniemation posted Thu, 17 November 2016 at 2:42 PM
Hi I've tried everything. Drag and dropping files inside Poser, the add content button inside Poser and nothing gets the Millennium Cat to show up in the Poser 11 library. Any ideas? I downloaded Poser 11 a couple days ago and downloaded all the files for it. Is there something else I need?
donnena posted Thu, 17 November 2016 at 2:47 PM
Hi!
Where did you install the Mil cat to?
Do you have a DAZ installer or is it a zip file?
Thanks!
Andy!
anniemation posted Thu, 17 November 2016 at 2:55 PM
I used the zip file for inside Poser installation and unzipped it and put it into the downloads folder inside Poser.
Boni posted Thu, 17 November 2016 at 4:53 PM
You need to get the "runtime" out of the "content" folder because DAZ's hierarchy set up slightly different.
Boni
anniemation posted Thu, 17 November 2016 at 4:56 PM
Thank you!
anniemation posted Thu, 17 November 2016 at 7:10 PM
Wait. How do I do that exactly?
hborre posted Thu, 17 November 2016 at 8:35 PM
You need to open the zip file and go beyond the first folder called content. Everything within that folder should be extracted to your Poser content folder, not the content folder itself. Don't use Poser's decompression app on DAZ content zips, the installation will not apply correctly. BTW, where is your Poser content installed and what OS are you running on your computer?
anniemation posted Thu, 17 November 2016 at 9:23 PM
Thank you I got it working. I pointed Poser to the installed Daz content folder and stuff seems to show up!
