Eroticartist opened this issue on Nov 25, 2016 ยท 7 posts
Eroticartist posted Fri, 25 November 2016 at 9:39 PM
I just wanted to make sure that this is correct. Victoria 7 and Genesis will only work is Poser 8 and up?
SpookieLilOne posted Fri, 25 November 2016 at 10:27 PM
Victoria 7 and genesis 3 are for daz studio
There is a tool by wildial for making them work in poser 11
https://www.renderosity.com/mod/freestuff/genesis-3-poser-updater/76121
It will not work in any version older than poser 11
*~*Jamie*~*
"Life is just a dream on the way to death." ~The Crow: City of Angels
hborre posted Sat, 26 November 2016 at 5:05 PM
Clarification, do you mean Genesis or referring to Genesis 3? SpookieLilOne is correct about Genesis 3 and the workaround, however Genesis can be imported into P8 and higher through DAZ DSON Importer.
Tracybee posted Sat, 26 November 2016 at 5:21 PM
hborre posted at 5:19PM Sat, 26 November 2016 - #4291033
...And good luck with that !! I'd read all the Forum posts on that so called "importer" before you bother with it. But it will keep you busy and away from anything productive :)
Richard60 posted Tue, 29 November 2016 at 6:57 PM
@hborre Pretty sure you mean Poser 9 and up. 9 is when weight mapping came in and IIRC it wasn't until SR3 that the DSON importer would work.
hborre posted Tue, 29 November 2016 at 8:10 PM
Stand corrected. Didn't get an opportunity to check the specs at the time of posting. Thanks.
Eroticartist posted Wed, 30 November 2016 at 9:06 PM
Thanks everyone! I am still using Poser 7. I tried 8 but it was so different and I didn't have the time to figure it out. I appreciate your responses!
