jakubon opened this issue on Dec 03, 2016 ยท 7 posts
jakubon posted Sat, 03 December 2016 at 5:07 PM
Hi
I have problem with fullbody morphs.
I wos buy m4 and v4.2 and there wos only files to copy, no install. I pasted it to runtime and see models & INJ morphs in library, but it dosnt work on full body. After inj morphs + or ++ i dont see any new parameters on full body, When i chose one of bodybuild form library nothing is happen.
could you help me ?
ps. sorry for my english...
willshetterly posted Sat, 03 December 2016 at 6:35 PM
Try asking on the DAZ Forums. I know there's something you have to do to make Michael 4 work on your computer, and I can't remember what it is right now. Sorry!
willshetterly posted Sat, 03 December 2016 at 6:37 PM
This might help: https://helpdaz.zendesk.com/hc/en-us/articles/207530793-How-to-install-Michael-4-0-and-M4-Morphs-into-Poser-on-the-PC
donnena posted Sat, 03 December 2016 at 7:07 PM
you have to run the batch file.
It's located in the Runtime/Libraries/!DAZ folder.
There is one for his Gens, too, if you bought them.
Andy!
hborre posted Sat, 03 December 2016 at 7:10 PM Online Now!
Nope, sorry willshetterly, this is not the solution. M4, as well as V4, need to be initialized before they accept any morph package. Assuming that the OP is using a Window based computer, follow this path where M4/V4 is installed: Runtime>Libraries>!DAZ
Within the !DAZ folder, find the DzCreateExPFiles-M4.bat for M4 or DzCreateExPFiles-V4.bat for V4 and double-click these files to initialize the base models. This should be run after each and every morph package installed into the runtime. But also be aware, base models and morph packages must be installed in the same runtime and not in Program Files folder if you are running Vista or higher. There are severe problems if everything is installed into the application runtime folder.
Edit: beaten to it.
willshetterly posted Sat, 03 December 2016 at 7:31 PM
donnena and hborre, that's what I couldn't remember! It should solve jakubon's problem.
jakubon posted Mon, 05 December 2016 at 3:04 AM
WOW :D Thanks for a such interest! Its work, i do what you sugest and its fine now. Thank You all. Cheers
