inquire opened this issue on Dec 15, 2016 ยท 3 posts
inquire posted Thu, 15 December 2016 at 3:14 PM
Just went up to Mac OS 10.12.2, Sierra, on Tuesday, when it was released. Then I updated from Poser 11 Pro 11.02 to v. 11.05. What happens is that when I start Poser, the Library (floating) panel shows up as completely blank. There's no way to search for a Runtime folder or anything. Then, I quit Poser, and then restart. The Library then appears with Runtime folders in it. Is there any way to avoid or correct this strange behavior? I sure hope it doesn't go to a blank Library panel permanently. It's a little unnerving to see it do that.
By the way, I also have Poser 2014 Pro on my HD, and it starts up with the Library operating fine, with the Runtime folders showing.
ironsoul posted Thu, 15 December 2016 at 11:08 PM
Have you searched the Poser forum, I've seen mention of this or a similar problem posted there. The answer I saw was to select the refresh button found bottom right.
inquire posted Fri, 16 December 2016 at 3:38 PM
Oh, a different Forum? Oops, sorry if I posted this in the wrong place. OK, I'll look for another forum, and I'll keep in mind a refresh button found bottom right. (Seems like the entire Library panel is blank, but I'll check.) Thanks.
You are right, ironsoul: There is a greyed out Refresh button in the bottom right corner. I clicked on it, and all the Runtimes appeared in the Library. Thank you very much.
