wheatpenny opened this issue on Jan 05, 2017 · 21 posts
wheatpenny posted Thu, 05 January 2017 at 1:15 PM Site Admin
Version 4.9.3 is now out. You can find it in your product library at Daz.
Jeff
Renderosity Senior Moderator
Hablo español
Ich spreche Deutsch
Je parle français
Mi parolas Esperanton. Ĉu vi?
Tom2099 posted Sun, 08 January 2017 at 11:30 AM
The new version of Iray (Nvidia Iray 2016.3) that comes with the latest beta of Daz Studio (4.9.3.166) is noticeably faster than the version that came with the latest stable release version of DS (4.9 from last summer), which by itself is reason enough to download it.
Razor42 posted Mon, 09 January 2017 at 5:46 PM
There are also 360 render modes available which can easily be moved over to VR.
atpo posted Wed, 18 January 2017 at 7:43 PM
Thanks.
fried_gold posted Tue, 14 March 2017 at 2:53 AM
Forgive my density but can I get this via "Edit ==> Preferences ==> Check for Updates Now"?
EDIT: I should point out that I can only see the vanilla "Daz Studio 4.9 Pro" in my product library
RHaseltine posted Tue, 14 March 2017 at 10:44 AM
If Help>About Daz Studio does not show you are running 4.9.3.166 then download 4.9 from your product library. DS doesn't get patches, it's a full version install each time.
CHK2033 posted Tue, 14 March 2017 at 11:05 AM
Razor42 posted at 11:04AM Tue, 14 March 2017 - #4294775
Wait what? Where is it?
HP Zbook 17 G6, intel Xeon 64 GB of ram 1 TB SSD, Quadro RTX 5000
Razor42 posted Tue, 14 March 2017 at 7:40 PM
In the Camera settings, you can set your camera to render Spherical under lens in the Parameters. The result is a 360 degree spherical render which you can use in both Daz and other 3d apps.
Razor42 posted Tue, 14 March 2017 at 7:47 PM
Here are some vids made with it. https://www.youtube.com/playlist?list=PL403UZF5-5dIRzfe0i4NVT-GyicTfVvpE
fried_gold posted Wed, 15 March 2017 at 3:34 AM
RHaseltine posted at 3:34AM Wed, 15 March 2017 - #4299325
That did it! Much obliged m'friend
prinzeugen12 posted Thu, 04 May 2017 at 4:00 PM
I am running an earlier version of Daz 4.9.. I cannot seem to download the latest version in 64 bit.. I go to the Daz web site main page , click on technology, then click read more and Download, then click get started today, then click 4.9 64 bit for windows install manager ready... once my install manager loads there is no daz 64 bit waiting to be downloaded... tried the download without IM and nothing in my download file... What am I doing wrong ??
RHaseltine posted Fri, 05 May 2017 at 8:47 AM
Click the Download Filters button on the Ready to Download tab of DIM and make sure that 64 bit software is checked. You should be able to get the current version from there without having to go to the Daz site - the latest of 4.x is always there
prinzeugen12 posted Sat, 06 May 2017 at 8:10 AM
RHaseltine posted at 8:06AM Sat, 06 May 2017 - #4304397
Still nothing shows up in DIM with the filter button checked... I have the latest 32 bit download...in DIM I can uninstall my 64 bit ...Should I ??? Im using Chrome as my broswer and windows 7 ultimate... Very strange I cannot download this ,very frustrated..
RHaseltine posted Sat, 06 May 2017 at 9:40 AM
Are you sure you don't have the current version, 4.9.3.166? Check Help>About Daz Studio.
prinzeugen12 posted Sat, 06 May 2017 at 7:53 PM
No it was 4.9.1.30 I deleted it and content manager.. I found 4.9 on page 7 of my products page of my account.. tried to load through DIM but it never showed up in downloadable files.. I was able to manual download but it never completely installs . It gets to 95% Installing Content manager Service and it keeps going for hours and hours... Never fully installs... Wow ! I never had any trouble upgrading from 4.8 to 4.9 ...this is a nightmare..
RHaseltine posted Sun, 07 May 2017 at 9:39 AM
Was the process that was hanging the Valentina to PostgreSQL conversion utility? That shouldn't be used, I would think, if you were already using DS 4.9.x.
If you installed the Default filters for install manager you should be able to click the triangle to the left of the filter text box, at top-right, and set DIM to show only software - what do you have listed in each tab (while online)?
Kerwin64 posted Sun, 04 June 2017 at 12:19 AM
Hello all! Does anyone know how to upload Renderosity content into DAZ Studio 4.9? I see the files that have corresponding names for DAZ but there's no instructions or tutorials on where to place the files correctly.
Thanks for your time!
flibbits posted Fri, 16 June 2017 at 12:02 AM
What I generally see is a CONTENT folder that contains three sub folders: People, Data, Runtime (Sometimes may be Props) Whatever folders are in the CONTENT folder go in your DAZ3D/Studio/MyLibrary folder.
Marque posted Thu, 06 July 2017 at 4:50 AM
Having problems with the newest download on a new system with no content loaded. Installed the install manager and downloaded the newest studio but I get this message when I open studio A valid PostgreSQL CMS connection could not be established. How do I fix this? Thanks, Marque
Marque posted Thu, 06 July 2017 at 4:51 AM
Says my version is 4.9.4.117
Marque posted Thu, 06 July 2017 at 5:01 AM
This is what I get in the Install Manager log WARNING: dzvalentinaobjectdatabase.cpp(38): DB Register Open error: Cannot establish VC_Connection with remote server. Make sure the server address and port number are correct.
