Forum: Poser 11 / Poser Pro 11 OFFICIAL Technical
Subject: NVidia GTX 1070 won't work in Poser 11 (Superfly)
Anagord opened this issue on Jan 05, 2017 ยท 7 posts
Anagord posted Thu, 05 January 2017 at 5:41 PM
Can someone tell me how to manage my card to work in Poser Pro 11? :) I am using it for Iray renders and it works well but in Poser it just shows black render. :)
3d_Rancher posted Thu, 05 January 2017 at 6:15 PM
It could be a video driver issue. I have a gtx 1070 also and was having troubles rendering when I updated to the latest driver. Instead of installing the latest one from nvidias website I stuck with the one windows update installed automatically.
I'm using version 372.90
There is an older post in the forums which mentions someone installing version 375.95 and also having issues.
jura11 posted Thu, 05 January 2017 at 7:44 PM
Hi there
Please update drivers to 373.06,I'm using these drivers and these drivers works like with IRAY or Poser
Hope this helps
Thanks,Jura
Anagord posted Sun, 08 January 2017 at 7:42 PM
Hi jura11 :)) THANK YOU SO MUCH!it is working now! :)) One more thing..When I want to export v4 into Zbrush via export/Zbrush,Poser crashes immediately! :( Any help? :))) Kind regards Gordana aka Anagord
jura11 posted Sun, 08 January 2017 at 8:42 PM
Anagord posted at 2:37AM Mon, 09 January 2017 - #4294695
Hi Gordana
Do you have installed as well Poser 10(2014) and if yes does there works GoZ/ZBrush?
If yes then I would suggest back up existing profile Users/Public/Pixologic/GoZApps/Poser and delete content of this folder, but backup first this folder
And then relink ZBrush with Poser 11,are you using 32bit or 64bit?
Hope this helps
Thanks, Jura
Anagord posted Mon, 09 January 2017 at 9:46 AM
Hi Jura All good now my computer was making issues lol Thank you again so much! :)
robognome posted Wed, 08 February 2017 at 2:42 PM
I just updated poser11 with update 6. It appears to correct the problems superfly has with gpu rendering using my 1080 card, even with more recent drivers. I have 376.53 drivers installed.
It even worked with "branch path" tracing option on, although it still issues the warning when you set it.
