McGrandpa opened this issue on Feb 20, 2017 ยท 3 posts
McGrandpa posted Mon, 20 February 2017 at 11:28 PM
Right, Scene files, VOB files. I keep getting the same type of error even on freshly installed items.
Thing is, I can select the object after it loads, go up to the texture ball, and show the actual texture it said it could not find. BUT it will not render it, nor can I load a new texture on the item and it show. It just renders black.
I do NOT have content installed on C: drive at all. Nope. I DO have content installed per directions in the docs, and did add the entire set of D:Vue Content folders and files to collections in the various browsers inside Vue. So, whats my problem here? How do I convince Vue to use what it saved out its own self?!?
THANKS in advance!
McG.
My 66th Birthday PC Build (July 1, 2020) : named BadMoonRYZEN!, W10Pro x64, Octal Core RYZEN7 X3700 4.05 GHz, 64GB DDR4 RAM, GeForce RTX 3060 - 12GB GDDR6, PP2014, PP 11, P12, PS-CS4 Extended & Vue 2024.
McG.
TheBryster posted Thu, 23 February 2017 at 9:55 AM
I'm tempted to ask the most simple question here. Have you rebooted/cold started your PC recently? I ask because I had to reboot after my PC decided I didn't have any drives.
McGrandpa posted Thu, 23 February 2017 at 7:56 PM
Yes, more than once actually. I did have to reinstall the OS and all software, after all. Thanks for the suggestion! McG.
McG.
