Burpee opened this issue on Feb 25, 2017 ยท 3 posts
Burpee posted Sat, 25 February 2017 at 1:41 PM
I made a correction morph for my object that I want to be permanent. I set it to '1' and hidden, memorized and saved. When I select 'zero figure' it resets it to '0' making it useless. This only happens if I have 'show hidden parameters' checked on. If I uncheck that then it does not reset the morph back to zero. Is this suppose to happen? I don't remember that happening n PP2014.
ockham posted Tue, 28 February 2017 at 10:02 AM
You could try using the Limits to keep the morph at 1. Something like this:
targetGeom rightarmup
name rightarmup
initValue 0
hidden 0
enabled 1
forceLimits 1
min 1
max 1
Note that Force Limits is 1, and min and max are both 1. The Zero Figure command doesn't zero this morph.
This may not work with a spawned morph; I think those are different somehow.... but it definitely works with a 'regular' morph that has deltas.
Burpee posted Sun, 10 December 2017 at 1:41 PM
Hey Ockham, sorry that I somehow missed your response. I was cleaning out my email folder and found a link back to this thread. Great info and it's how I fixed the issue. Cheers!
