Subject: Change in V4's setup??
VolcanicMink opened this issue on Mar 05, 2017 · 6 posts
VolcanicMink posted Sun, 05 March 2017 at 5:22 PM
I have reloaded V4 straight from the DSON, but now I only have 3 icons under the Pose menu. V3.PNG There used to be a 4th with just her mug shot, which was what I used to get V4 on the screen. The one I have here was just for V3 last I knew. v4 missing.PNG I have removed and downloaded 7 times, restarted the computer, disk-cleaned, defragged, everything I can think of. I have run the batch file, and still the morphs won't work, probably because they're not made for V3. Please help!! I'm running out of hair to pull out!!
willyb53 posted Sun, 05 March 2017 at 6:16 PM
I can not help you with V4, but IIRC there should be a seperate morph inj for v4 to v3 Bill
People that know everything by definition can not learn anything
Sa_raneth posted Sun, 05 March 2017 at 6:27 PM
try downloading her manually see if that helps
Helos posted Sun, 05 March 2017 at 6:48 PM
Yes, Sa_raneth is right. you should install V4,2 manuelly.
That's my download:
I don't know, what the "Dev-files" can do.
Henning
Kazam561 posted Tue, 07 March 2017 at 2:39 AM
I think the Dev-files are for those who want to try developing content. Installing manually should get you all the files, but you should put in a ticket with their help desk. They might not be aware of the DIM not installing that content any longer. On the other hand, they have dropped most older V3 content. I for one just picked up a texture for V3 last week from another website.
The dust settled, thinking "what a fine home, at least for now" not realizing that doom would soon be coming in the form of a vacuum cleaner.
WandW posted Tue, 07 March 2017 at 10:03 AM
If you install her manually, make sure to reinitialize her afterward...
