kenmo opened this issue on Jun 07, 2017 ยท 67 posts
kenmo posted Wed, 07 June 2017 at 12:08 PM
I own and use 3DCoat since version 3. Currently using version 4.7. I love 3DC. It's awesome and very easy to use for UV Mapping, texturing, painting and sculpting. Well worth the money. BUT I hate manual retopoing.
Can't stand the process and I find the task in 3DC not enjoyable. Too tedious and too long of a process for me to retopo a model I will only use once or twice in a Vue render or use as a paintover in Photoshop/Painter/ArtRage.
I used the free tool Instant Meshes and with a click of a button a model is retopologized in a few minutes compared to 3DC's auto retopo which on certain models could take a couple of hours. But Instant Meshes is hit or mess. So is 3DC's auto retopo.
I've read and watched videos of Topogun and it seems interesting and cheap.
I know Blender has retopo tools, but sorry I'm not a Blender user.
For the time being I am using 3DC to decimate my 3DC sculpts.
Anyone have any thoughts, tips or recommendations?
And I would appreciate it if people do not post trying to convince me Blender is the answer. Sorry not wanting to be rude, but I have little interest in Blender...
LuxXeon posted Wed, 07 June 2017 at 2:57 PM
Zremesher is without a doubt the best automatic retopology algorithm I've tried so far, and yes I've used Instant Meshes interactive field alignment algorithm and 3dCoat's AutoTopo as well. Both of those are fine in their own right, but Zbrush's method and double algorithms are much more precise and result in a much cleaner topology which can actually be used on its own in production for non-animated objects, unlike some of the results from Instant Meshes. Of course, there is no automatic retopology process which will be perfect in the end. There is no way to automatically retopologize a mesh and expect results to be as good as manual retopology by someone who knows what they're doing. However, in terms of a clean, usable result with only minor issues in edge flow, Zbrush wins that comparison hands down as long as the result is a static object.
Topogun does not have automatic retopology features as far as I am aware. It is an older, although more cost effective, solution to manual retopology. Please do not hesitate to correct me with some links to show the automatic retopology examples in Topogun if I am wrong in that observation.
I am curious when you say that the AutoTopo feature in 3dCoat is taking hours for you, though. I know it's not as fast as Zremesher or Instant Meshes in some cases, but I've never seen it take longer than maybe 5 minutes on even the most challenging mesh. I wonder why it's behaving that way for you?
______________________________________
My Free Models
My Video Tutorials
My CG Animations
Instagram: @luxxeon3d
Facebook: https://www.facebook.com/luxxeon
cjd posted Wed, 07 June 2017 at 7:19 PM
I watched an impressive video on using poly groups in ZBrush to remesh some CAD objects. Honestly though, when I just want to get a good render and really don't care about having the mesh for other uses, it seems like a lot of work. I can't justify the time for that. I don't mind some triangles, I would not complain if the mesh was all triangles, as long as it renders good.
At least for my application starting with the best mesh output from CAD seems to be the key. If Moi's output is consistently as good as I have seen I'll have to pick up a license.
LuxXeon posted Wed, 07 June 2017 at 9:29 PM
The Zremesher tool in Zbrush is a one-click auto-retopology process. It will create new quad geometry on a dense mesh automatically. Very simple and fast algorithm.
My Free Models
My Video Tutorials
My CG Animations
LuxXeon posted Wed, 07 June 2017 at 9:33 PM
Here's a good representation of the what the tool can be useful for. It provides very good, usable results in one click. However, it can never substitute good manual retopology.
My Free Models
My Video Tutorials
My CG Animations
cjd posted Wed, 07 June 2017 at 10:12 PM
I have tried ZRemesher, and its prone to producing artifacts with meshes from CAD, which I don't think is the fault of the algorithm. CAD meshers in general don't care about producing sliver like triangles. The meshes are typically intended for 3D printing and generally these sliver triangles don't present an issue there. It's possible the polygroup retopo method would still have issues with these triangles.
Its possible the issue is with normals, although I would need to look at it further. The difference between facet normals and vertex normals could be relevant. Perhaps the issue is not so much with the proportion of the triangle, but how the normal is calculated for that triangle. In the end I don't really care whether its a geometry issue or a normal issue. I just want a nice render that doesn't cost me a lot of time to remesh/retopo.
cjd posted Wed, 07 June 2017 at 10:54 PM
I watched both of those videos Luxxeon, Thanks.
The Projection method might have some potential, have to give that a try.
infinity10 posted Thu, 08 June 2017 at 12:36 AM
I use Shade3D. I has a retopology function as well. Does what it has to do.
Eternal Hobbyist
LuxXeon posted Thu, 08 June 2017 at 12:39 AM
The Zremesher is most useful when retopologizing objects of densely packed Delaunay triangulation or quad surface structure, typically after the sculpting process . Long thin triangles created from CAD applications, such as those associated with Sketchup, will usually present problem for any automated quadrangular mesh algorithm for exactly the reasons you've indicated, among other things. There just isn't enough surface information in such models for the algorithm to work properly. Using "guide splines" on the surface of the model before launching the tool can help the algorithm solve itself sometimes, but that is often not enough in itself to keep the result from being 100 percent efficient. Some form of manual editing will almost always be necessary after the automation is complete.
Personally, I almost always model from scratch using standard polygonal techniques and subdivision methods to avoid this problem down the road when working with hard surface objects. When it comes to sculpting detail in organic objects, I will usually do retopology manually as well. I actually enjoy the process of retopology, and find the tools relatively fast and efficient in packages like 3dcoat or 3dsmax, etc. In the rare case when I might do an automated retopo project, it's usually only on models where detailed sculpting has pushed the polygon count up into the astronomical range, and redistribution to a render or animation pipeline would be far too inefficient. In such cases, the objective right from the start is to sculpt fine detail in Zbrush or 3dCoat in order to extract nomal maps or other PBR maps to use on a low-resolution static base mesh anyway, so edge flow really doesn't matter.
My Free Models
My Video Tutorials
My CG Animations
LuxXeon posted Thu, 08 June 2017 at 9:12 AM
infinity10 posted at 9:11AM Thu, 08 June 2017 - #4307010
Is it automatic or manual retopology?
My Free Models
My Video Tutorials
My CG Animations
SinnerSaint posted Thu, 08 June 2017 at 9:38 PM
Modo has automatic rettopology since version 10. https://www.youtube.com/watch?v=1IPmzasXj2A
LuxXeon posted Fri, 09 June 2017 at 2:43 PM
SinnerSaint posted at 2:26PM Fri, 09 June 2017 - #4307082
That's the 10.2 update, but interesting nontheless. Their solution actually seems comparable to Instant Meshes, and may actually be using the same fields alignment routines as a basis for the tool. In fact, I'm sure all of the automatic retopology processes out there are based on relatively similar processes, with the exception of 3DCoat's old quad output algorithm, which they have since made obsolete in their later AutoTopo feature.
Just for fun, I decided to run a test of my own in Zbrush using the ZRemesher algorithm. Note that there are actually two distinct algorithms for ZRemesher, the second of which can be accessed simply by holding down the ALT button on the keyboard when you click the UI button to engage the tool. This test simply uses the standard automatic retopology method. The only changes I made from the default values was that I set the Target Polygons Count from the default 5 value, down to 2. All other settings in the tool remained at the default.
Here is a screencap of the ORIGINAL geometry exported from 3dCoat to Zbrush from the Voxel sculpt. No, the object is not black, it's actually the red clay material which is default in Zbrush, but the polygon count is so high the polyframe view (wireframe edges) make the object appear solid black. There are over 4 million triangles in this object.
And here is the object after automatic retopology in ZRemesher. It now contains only 27,000 quad polygons. That's a reduction of around 675%. The process took about 12 minutes on my i7-7700HQ CPU running at 2.8GHz.
My Free Models
My Video Tutorials
My CG Animations
LuxXeon posted Fri, 09 June 2017 at 3:10 PM
Here now is the Instant Meshes results on the exact same high poly object as shown above. I did not adjust any settings in the IM software besides reducing the desired poly count to around 29,000. The exported mesh here is not entirely quadrangular. The export resulted in just under 29,000 polygons but there were also ngons in the result. Subdividing this, of course, would solve that but I'm not entirely sure why the software couldn't come up with a pure quad mesh like ZRemesher did. The calculations here though were faster than ZRemesher. This result took less than 3 minutes on the same machine as above.
Personally, I would not be satisfied to use this output in production straight away. I would have to either edit the results manually to fix the ngons, or subdivide the object to attain pure quad topology.
My Free Models
My Video Tutorials
My CG Animations
davidstoolie posted Sat, 10 June 2017 at 12:13 AM
Yep, when you really look at the zbrush output compared to the other one, it looks a lot cleaner. Thanks for posting your tests! I would be curious what the 3dcoat output looks like on that same model.
LuxXeon posted Sat, 10 June 2017 at 1:33 PM
Here you go. I could not get 3dCoat's new AutoTopo algorithm to work properly on this particular model out of the box with default settings. Even changing a few parameters did not work out. So, I had to resort to using the Old-Style Quadrangulation method, and this is the results of that procedure. Same model as the others. Time to complete in this case was around 2 minutes, which is faster than either of the previous tests. However, I'm not happy with the results here for various reasons. The model is not all quads. We have 21 triangles, 127,968 quads, and 2 ngons.
My Free Models
My Video Tutorials
My CG Animations
LuxXeon posted Sat, 10 June 2017 at 1:47 PM
So, to sum up the testing in all three auto retopology applications:
Zbrush with ZRemesher: 12 minutes to complete, 27,000 polygons, all quads, clean usable mesh.
Instant Meshes: Less than 3 minutes to complete, 29.000 polygons, mostly quads with several ngons, usable with subdivision or manual cleanup.
3dCoat with Old Style Quadrangulation: Less than 2 minutes to complete, 21 triangles, 127,968 quads, and 2 ngons, I wouldn't use this mesh in production.
Mileage will vary, but there you have it. If anyone has any other automatic topology applications they would like to try on the same model, let me know. I don't have access to any other automatic topology tools at the moment. I don't think Blender has an automated retopo feature currently. Blender uses semi-automated techniques with the grease pencil tool, but that's not the same. The only other tool I know of is this one:
http://igl.ethz.ch/projects/sketch-retopo
However, that is not fully automated retopology either as far as I can tell. Also, it seems to require compiling?
Edit: If you download the source code of the Sketch Retopo project I'm linking to above, there is a binary installation file in the zip. Just in case anyone wanted to try that software out.
My Free Models
My Video Tutorials
My CG Animations
kenmo posted Tue, 13 June 2017 at 11:50 AM
I find 3DCoat's auto retopo takes a long time. Sometimes even over an hour.
cjd posted Tue, 13 June 2017 at 1:07 PM
How many polys in the model you are starting with?
kenmo posted Tue, 13 June 2017 at 1:29 PM
1 to 2 million. I love 3DCoat but not for retopo work.
LuxXeon posted Tue, 13 June 2017 at 9:21 PM
3dCoat's AutoTopo tool requires you to use symmetry to help the process along. I tried this with my test model, but it was still unsuccessful with default settings so I had to use the old style quadrangulation. My question to kenmo would be what are your computer specs? I found 3dCoat's algorithm to be the fastest of the 3 I tested on the same model, same machine, with default settings for each. The difference is that 3dCoat could not successfully resolve the object type I used for some reason with the newer algorithm.
My Free Models
My Video Tutorials
My CG Animations
ShawnDriscoll posted Wed, 14 June 2017 at 5:36 AM
3D-Coat's autotopo has worked fine for me in the past. I haven't tried it with the latest beta though. I don't recall it ever taking longer than a minute to do its thing.
kenmo posted Wed, 14 June 2017 at 8:58 AM
I7-4770 with 32 gbs of DDR3 memory and GTX 750ti 4gb. Windows Home 10 64 bit. Bootup drive is a Samsung 500gb SSD. Has multiple mechanical drives for data (Sata2, Sata3 & USB 3.0).
I've also tried the same auto retopo on my i5-2500K with 16 gbs and the process is the same. Very slow. Anyone interested can download my free Gunship model here at Renderosity and try an auto retopo on it... It's a very dense model. I gave up on an auto retopo and uploaded the sense model here....
https://www.renderosity.com/mod/freestuff/pain-merchant/70418
cjd posted Wed, 14 June 2017 at 9:19 AM
Blender has a remesh function but mangles the normals on many of the new polys, and the Octree (comparable to # of subdivisions) has to be set very high which generates an excessive # of polys just to get something that looks like what you started with. There does not seem to be any adaptive subdivision.
LuxXeon posted Wed, 14 June 2017 at 12:08 PM
kenmo posted at 12:05PM Wed, 14 June 2017 - #4307456
I assume you are not attempting to retopo this model as one single piece?
My Free Models
My Video Tutorials
My CG Animations
ShawnDriscoll posted Wed, 14 June 2017 at 12:58 PM
cjd posted at 9:54AM Wed, 14 June 2017 - #4307458
I'll import a mesh (with bad normals) into Hexagon and unify everything. Then export to Carrara to crease whatever edges need to be creased. I think 3D-Coat works much better if models have creases to help its UV mapping calculations.
LuxXeon posted Wed, 14 June 2017 at 2:07 PM
When using AutoTopo in 3dCoat, it is strongly suggested you enable symmetry even if the model does not have perfect symmetry. Using symmetry will help reduce the calculations required by the algorithm to manageable levels on most objects. However, this did not help in the case of my test object. The AutoTopo took approximately 2 minutes, but the results were mangled and completely useless rats nest geometry. I'm sure had i incorporated some guide splines and density preferences I could have solved this issue, but that wasn't the point of the testing here.
Kenmo, I downloaded your model to have a look. The ship contains many small, intricate pieces which should be separated and re-topologized on their own as individual models, then combined with the main part of the model later. This is probably why AutoTopo calculation is taking so long for you in this case. Frankly, I'm surprised it's able to give you a result at all considering all of the smaller detailed parts on the model.
My Free Models
My Video Tutorials
My CG Animations
ShawnDriscoll posted Wed, 14 June 2017 at 5:44 PM
kenmo posted at 2:38PM Wed, 14 June 2017 - #4307456
Having issues loading that OBJ into anything. I've never used DAZ Studio. So don't know what kind of OBJs it outputs. 94MB seems a bit much for a ship like this.
LuxXeon posted Wed, 14 June 2017 at 7:29 PM
Shawn, I took a look at the ship and I can see what the problem is there. Kenmo's model contains a massive 1.7 million polygons. That's a huge number of polygons for most people running average hardware to load in most enthusiast level 3d software. Although it is a very nice looking model with a great design, the object will, unfortunately, be far too heavy for most average users. Also, I think the reason it was taking so long to retopo is that it contains a number of very small subobjects and greebles, which should all be retopologized separately, then merged together afterward with the main part of the model. This would allow you to retopologize much more efficiently.
My Free Models
My Video Tutorials
My CG Animations
cjd posted Wed, 14 June 2017 at 8:04 PM
@Shawn
I hadn't considered Hexagon ... although I have used it to unify/flip normals. I was under the impression Hex was pretty limited when it comes to any normal adjustment beyond unitfy and flip. It can't smooth normals and/or crease edges.
OK, I see you use Carrara for crease edges.
ShawnDriscoll posted Wed, 14 June 2017 at 10:32 PM
You can crease edges in Hexagon 2.x. But 2.x has so many bugs, it's a joke to use that version for anything. Hexagon 1.21 has zero edge-creasing ability.
There's a couple types of normals with polygons. Their facings (when their normals are flipped), and their phong shading (used for normal mapping). I use Hexagon 1.21 to fix both types. I then import the model into 3D-Coat to do UV mapping.
kenmo posted Thu, 15 June 2017 at 6:44 AM
I've loaded my model into Hexagon 3D 2.5 and into Vue Complete but does it ever weigh down my system...
LuxXeon posted Thu, 15 June 2017 at 2:03 PM
kenmo posted at 1:59PM Thu, 15 June 2017 - #4307526
I think anyone running under 16gb of system ram with memory intensive applications would have a difficult time loading or working with your model in a scene. It is a very nice model, but it could definitely use a reduction in polygon count to be more useful to the average enthusiast. Again, I think the complexity and multiple small parts contained in the model can not expect to be retopologized automatically all at once. Breaking it down and retopologizing each part individually should prove much faster for you.
My Free Models
My Video Tutorials
My CG Animations
ShawnDriscoll posted Fri, 16 June 2017 at 6:43 AM
kenmo posted at 3:39AM Fri, 16 June 2017 - #4307526
What I would try doing is re-tessellate your ship (in whatever app you used to model it) to a lower-res poly-count. But then you probably wouldn't need to re-topo it, after doing that.
If you made this ship with voxels, just bust it apart and re-topo each part separately (again, in lower-res poly-count).
ShawnDriscoll posted Fri, 16 June 2017 at 6:51 AM
LuxXeon posted at 3:44AM Fri, 16 June 2017 - #4307569
I have 32GB RAM. But my 64-bit apps have trouble with this model because of corruption, and vast data associated with each poly on this model. The poly count doesn't look that high. It's the kind of polys it's using that are jamming the works. Shader domains seem to conflict with object names that seem to conflict with material names. Then there's the OBJ export that has its own 10's of standards for its formatting.
I assume Kenmo still has the original model in its native format before any OBJ exporting was done with it, so that the ship can be easily saved.
LuxXeon posted Fri, 16 June 2017 at 10:45 AM
ShawnDriscoll posted at 10:38AM Fri, 16 June 2017 - #4307632
You are right it's not 1.7 million. I'm not sure why Zbrush had reported that number. I opened it in 3dsmax, and here's the statistics.
It's over 882,000 polygons.
My Free Models
My Video Tutorials
My CG Animations
LuxXeon posted Fri, 16 June 2017 at 11:52 AM
After inspecting the model in 3dsmax, I found a few surface incontinuities in the topology which could result in some issues when importing into certain software packages. There are some unwelded vertices and overlapping edges in this part of the model...
Easily fixed, but the complexity of the boolean stitched polygons has created a lot of triangles and ngons that would need to be fixed as well. The model imported just fine in 3dsmax, but there are some shading glitches because of the polygon problems that do also show up in the render.
My Free Models
My Video Tutorials
My CG Animations
kenmo posted Sat, 17 June 2017 at 11:19 AM
The original base model was created in Groboto3D. Further parts and details in Hexagon3D 2.5 and Silo 3D ver 2. I used 3D Coat for texture painting but not for modeling. I did try retoping, both as a single object and then on individual parts. Retoping manually is too labor intensive for mespecially if I have to disassemble each part, retopo each part, then re-assemble.
I would much prefer a single click solution and that is the reason why Instant Meshes intrigued me.
I know there is a proper place for retoping manually...BUT... I only use my models once or twice in a Vue render or in a Photoshop/Painter/ArtRage paint over. I don't do animation...
I see the new beta of 3DC 4.7.29 has the option of retopo via decimation. Doesn't create pretty edge loops and such, but works for me...
Thanks for all the replies. Appreciate it...
cjd posted Sat, 17 June 2017 at 6:16 PM
kenmo posted at 6:14PM Sat, 17 June 2017 - #4307759
That sounds good, hopefully I can find a fast method to do that in ZBrush, will follow the tutorials Luxxeon linked to ...
LuxXeon posted Sat, 17 June 2017 at 9:27 PM
cjd posted at 9:24PM Sat, 17 June 2017 - #4307775
I'll be coming out with my own personal workflow tutorial for using Zremesher as a "one click" solution on my Youtube channel in the near future as well. My techniques will cover using it as a quick retopo solution for relatively complex hard surface models, and how to get usable results with almost no manual input. Let me know if there's anything specific you'd like to see covered and I'll see if I can make it happen. Can't promise I'll have it by the end of the month as there are some other videos I'm currently working on, but hopefully you find it useful.
My Free Models
My Video Tutorials
My CG Animations
ShawnDriscoll posted Sat, 17 June 2017 at 10:41 PM
kenmo posted at 7:39PM Sat, 17 June 2017 - #4307759
I thought in 3D-Coat, you could import an OBJ mesh and convert it to voxel and then do autotopo on that? Manually doing retopo would defeat the purpose.
cjd posted Sun, 18 June 2017 at 9:53 AM
Luxxeon,
Maybe going through the ZBrush stuff on my own would answer this question for me; however, since you are asking, one area that might benefit from additional explanation is how to preserve hard edges/surfaces from the original topology.
LuxXeon posted Sun, 18 June 2017 at 10:14 AM
cjd posted at 10:13AM Sun, 18 June 2017 - #4307806
Luxxeon,
Zremesher does a good job at preserving hard edges if you define boundaries first using masking and polygroups on the model. You may need to dynamesh the model first. Perhaps this tutorial can provide some insight.
My Free Models
My Video Tutorials
My CG Animations
cjd posted Sun, 18 June 2017 at 10:46 AM
LuxXeon posted at 10:42AM Sun, 18 June 2017 - #4307808
.... if you define boundaries first using masking and polygroups on the model.
OK, I see identifying a crease angle to define the areas is possible. Still not exactly push button for something down and dirty, but workable. Thx
kenmo posted Sun, 18 June 2017 at 12:52 PM
ShawnDriscoll posted at 12:52PM Sun, 18 June 2017 - #4307785
If you can, I'm not aware of this...
LuxXeon posted Sun, 18 June 2017 at 1:03 PM
cjd posted at 12:57PM Sun, 18 June 2017 - #4307811
When working with hard surface models where keeping sharp creasing and boundaries is a must, then there will be several more steps involved. Still, it's far easier than manual retopology and the results can be very good. The problem with quadrangular output directly from a CAD application, without any retopo, is that the mesh is often way too dense and not easily unwrapped or editable beyond that point. There's also the occasional surface artifact caused by triangles or ngons that the applications tend to insert with their algorithms. At least in the case of Zremesher, using the added steps of manually identifying boundaries and hard edges, the output can be quite low poly by comparison, and usually the topology is all quads or close to all quads, allowing the user the ability to further edit the mesh or subdivide the mesh later on down the pipeline if the object is for vfx or cg rendering. If the end goal is 3d printing, then there is still the benefit of a lighter and cleaner topology which can be useful if you upload to an online printing service like Shapeways, or wish to redistribute the mesh as a STL for others to use. Good luck. I hope you find the results worth it.
My Free Models
My Video Tutorials
My CG Animations
LuxXeon posted Sun, 18 June 2017 at 1:10 PM
kenmo posted at 1:06PM Sun, 18 June 2017 - #4307824
Kenmo, the technique Shawn is referring to is actually the preferred workflow for the AutoTopo process in 3dCoat. It would require you to export your model in smaller chunks. For example, you already have the model broken down into material groups, so each group would represent its own mesh output. You would import each smaller piece as a voxel object (with heavy subdivision to maintain detail), then apply a symmetry plane and run the autotopo routine on that piece. Once complete, you can export the retopo object as OBJ, and reassemble the model using the low poly parts. If you do the process correctly, the low poly retopo mesh should import back into the original scene in the same exact location as the high poly original.
My Free Models
My Video Tutorials
My CG Animations
kenmo posted Sun, 18 June 2017 at 3:15 PM
Sorry but I am not interested in disasembling and then re-assembling for retopologyzing. I find it very frustrating that the retopo process can take longer than the original modelling. I also find it too tedious and a waste of time to model a object a second time (retopologyzing).
There has to be a simple and easier process.
Cheers & many thanks...
LuxXeon posted Sun, 18 June 2017 at 4:58 PM
kenmo posted at 4:50PM Sun, 18 June 2017 - #4307844
I'm sorry, Kenmo. I feel perhaps I've misguided you with my own poorly worded overview of the process, and I may have left you with the impression that it's a lot of extra work. That really isn't the case at all. Yes, it does require a few extra steps (exporting and importing), but overall it's very simple and quick. Certainly not anywhere near the amount of time it would have taken you to model the object in the first place. However, if your current workflow and techniques are providing a satisfactory result, then that's all that really matters. As you mentioned, your models are really just intended for you, and used only in still image renders once or twice. So polygon counts and edge flows aren't really a concern in that case.
Keep up the good work. It's a very cool design by the way.
My Free Models
My Video Tutorials
My CG Animations
kenmo posted Sun, 18 June 2017 at 9:31 PM
No, I fully understood your reply as I've been told the same on the 3DCoat forum and have tried that process... Sorry but 3D modeling is only a hobby and a manual retopo doubles my time to create an object. And not only that I HATE the manual retopo process. I love everything about modeling, except retopo. Since it's a hobby I would rather spend my time doing stuff I enjoy, photography, Photoshop, Painter, ArtRage or doing 3D modeling in Silo3D, Groboto3D or Hexagon3D. I love 3DCoat for texturing & UV mapping. BUT not retopo work...
ShawnDriscoll posted Mon, 19 June 2017 at 4:52 AM
I have Groboto. Never used it. Not intuitive for me. But I did make a similar hull shape like your ship has from NURBS. I exported as OBJ into 3D-Coat just now and imported it into the Sculpt area and converted it to voxels (it retained the shape of the NURBS object, including the tight edges). It took about 4 seconds to make a 1.5 million poly voxel object. I then did AUTOTOPO on it, choosing 40,000 quad polys (the default). Took about 2 seconds to do. Then there were some questions 3D-Coat asked me. I had no idea how to answer. Just clicked next next next. Then exported the model as OBJ. Perfect. It was also auto-UV mapped along the way. Didn't even notice that happen.
kenmo posted Mon, 19 June 2017 at 10:14 AM
Groboto takes a while to get used to but once you do, it is quite easy. Sadly it looks like its gone the way of Beta video tapes, Studebaker autos and b&w televisions...
cjd posted Mon, 19 June 2017 at 10:30 AM
kenmo posted at 10:27AM Mon, 19 June 2017 - #4307942
They were acquired, I think by Luxology (Modo).
kenmo posted Mon, 19 June 2017 at 10:54 AM
I thought Mesh Fusion was a separate product (plugin for Modo) by Braid Arts who also developed/created Groboto3D... Groboto3D came to an halt when Darrell Anderson took quite ill...
LuxXeon posted Mon, 19 June 2017 at 11:00 AM
kenmo posted at 10:56AM Mon, 19 June 2017 - #4307949
Mesh Fusion is now an integrated module in the latest releases of Modo. It was originally a separate plugin, but no longer. I'm not a huge fan of Modo, so I don't know how deeply integrated the features are, but Mesh Fusion is actually a direct spinoff of the GroBoto technology. Darrel Anderson is actually working for The Foundry, and was one of the original designers of the Mesh Fusion product. Here's an article from 2016 about his work with The Foundry.
https://www.thefoundry.co.uk/blog/meshfusion-from-early-beginnings-to-future-thoughts
My Free Models
My Video Tutorials
My CG Animations
ShawnDriscoll posted Mon, 19 June 2017 at 10:41 PM
cjd posted at 7:36PM Mon, 19 June 2017 - #4307945
I have downloaded YouTube videos showing how to import Groboto into Modo. That was the last time I used Groboto, following the video tutorials. As far as I know, the two software packages are still separate. I don't know if the tuts would work with modo versions after Luxology sold modo. But then, you are in modo, which I find kind of a pain to model anything in. I only use it for rendering.
SinnerSaint posted Tue, 20 June 2017 at 6:09 PM
Modo came with Meshfusion as a integrated feature as of version 10.2
ShawnDriscoll posted Tue, 20 June 2017 at 6:49 PM
SinnerSaint posted at 3:46PM Tue, 20 June 2017 - #4308102
Ha! An 11-minute-long video showing how more convoluted modo has become. Using a Zero-Intuitive Interface(TM) for its basic modeling. modo should be renamed to chore.
cjd posted Wed, 21 June 2017 at 12:25 AM
LuxXeon posted at 12:18AM Wed, 21 June 2017 - #4307950
Ah, the Foundy, not Luxology.
When I first saw MeshFusion about 2 years ago my first thought was given enough time, it looked like it had the potential to make the whole nurbs vs polys issues go away.
LuxXeon posted Wed, 21 June 2017 at 2:06 AM
cjd posted at 1:35AM Wed, 21 June 2017 - #4308117
I guess in some ways, to some people, Mesh Fusion very well could be that "holy grail". The link between CAD modeling technology and polygonal based topology. Personally, I really don't see it quite that way yet. I guess if you were someone whose sole purpose was designing models that meet some form of standardized manufacturability and needed to optimize your time-to-market turnover, then something like Mesh Fusion could work very well, especially if your background was traditional modeling to begin with. If all you ever need from your models are machine-perfect chamfers, precision corners and perfectly fitted parts for fabrication, then Mesh Fusion can be that solution I suppose. However, for the kind of work I do, which can include making models for everything from additive manufacturing to pipeline animation rendering, there's still a lot to be desired from that kind of dense polygonal output.
My Free Models
My Video Tutorials
My CG Animations
cjd posted Wed, 21 June 2017 at 8:02 AM
To be useful to all, high frequency detail would have to be addressed. Perhaps there is no universal solution.
LuxXeon posted Wed, 21 June 2017 at 3:18 PM
cjd posted at 3:15PM Wed, 21 June 2017 - #4308134
Zbrush seems to have the best all around solutions to these types of issues for now. It's like the "swiss army knife" of 3d applications for just about any industry. I just wish the UI were a little more intuitive like 3dCoat.
My Free Models
My Video Tutorials
My CG Animations
cjd posted Wed, 21 June 2017 at 5:10 PM
I'm curious why the interface has not got more attention. For a 3D app it has the least functional interface I have ever used. Even Blender is better.
LuxXeon posted Wed, 21 June 2017 at 8:20 PM
cjd posted at 7:37PM Wed, 21 June 2017 - #4308171
Good question. The only thing I can think of is that Zbrush is already being used in almost every major VFX studio in the world, and also in most professional game studios. With that kind of enormous market penetration, reinventing the wheel in terms of the user interface is probably not a priority for developers at this time.
My Free Models
My Video Tutorials
My CG Animations
ShawnDriscoll posted Wed, 21 June 2017 at 8:50 PM
cjd posted at 5:33PM Wed, 21 June 2017 - #4308171
ZBrush programmers decided on using an artist workstation metaphor as its GUI. https://s-media-cache-ak0.pinimg.com/736x/6b/94/01/6b9401326b506c7e9182a4e6b16d90c7.jpg
So tools and settings and configs and overall usage of ZBrush is hidden everywhere. If I used only ZBrush, I'd get used to where everything is. But no. I have to relearn how to use ZBrush every time I feel like doing something in it.
Cars are easy to drive. Just point the steering wheel and press the go button. Cars are even easier to drive in computer games. ZBrush thinks its GUI is a master-of-arts-and-crafts ultimate hobby/tool shed, and should slow artists down while they work.
Again, if you only use ZBrush, it is the bomb. From stuff of legends, etc. If there was something I could do in ZBrush that was easier and quicker than how I do them in other apps, I'd be firing up ZBrush all the time to do that task. But i have found nothing so far that ZBrush makes modeling/painting/UV mapping/all of it easier for me.
Remember Sculptris? I used that thing night and day. It did the job. I had ZBrush already. Sculptris made me a non-Zbrush user. I think the reverse is supposed to happen, according to Pixologic.
LuxXeon posted Wed, 21 June 2017 at 10:44 PM
ShawnDriscoll posted at 10:34PM Wed, 21 June 2017 - #4308181
Good analogy, Shawn. That picture is almost like a mirror image of the Zbrush UI to me.
My Free Models
My Video Tutorials
My CG Animations
kenmo posted Thu, 22 June 2017 at 9:03 AM
ShawnDriscoll posted at 9:02AM Thu, 22 June 2017 - #4308181
Great points Shawn....
ShawnDriscoll posted Thu, 22 June 2017 at 8:57 PM
kenmo posted at 5:51PM Thu, 22 June 2017 - #4308204
Programs like 3DS and Maya and ZBrush (and even modo now) are not going to change how they work any time soon. Not while animation studios and training schools are using them. Industry-standard doesn't translate well for hobbyists like me, unfortunately. I like 3D-Coat, because it is still relatively cheap and it is easy to use still. One day, Pilgway will sell it off to some company. I hope it is later than sooner.
