DarkElegance opened this issue on Jun 12, 2017 ยท 6 posts
DarkElegance posted Mon, 12 June 2017 at 6:56 AM
My poor hard drive is running out of space. I have purchased a new external HD and was wondering can I just move my DS runtime etc to it or do I need to reinstall everything? Or do I install DS on that drive and then just move the content/settings over?
https://www.darkelegance.co.uk/
donnena posted Mon, 12 June 2017 at 9:55 AM Online Now!
Any of those solutions will work!
Happy rendering!
Andy!
DarkElegance posted Mon, 12 June 2017 at 10:05 AM
donnena posted at 10:05AM Mon, 12 June 2017 - #4307337
Happy rendering!
so I can just cut and paste my D|S folder to the new drive and it will still work?
Jack238 posted Mon, 12 June 2017 at 11:34 AM
so I can just cut and paste my D|S folder to the new drive and it will still work?<<
You also need to tell Daz Studio where you moved the libraries. I believe it is under the menu item Edit->Preferences->Content tab->Directory Manager->Content Directory Management Button
I am not sure if you are using Smart Content what changes need to be applied for that, if any.
FlagonsWorkshop posted Mon, 12 June 2017 at 2:29 PM
Jack is correct. I've moved bunches of stuff around like that. Not sure about smart content either, I don't use it. I do know if you change the folder location even on the same drive smart content will not work for what you moved. If you are using the DIM you also need to point that to where you want the files installed, that is separate from D/S
vitachick posted Tue, 13 June 2017 at 10:40 AM
I have my runtimes on external....
Win10 Poser 2014/Poser 11 Daz3D
