Forum: Carrara
Subject: Genesis Victoria 8 yep crash test dummi in carrara
MistyLaraCarrara opened this issue on Jun 15, 2017 ยท 12 posts
MistyLaraCarrara posted Thu, 15 June 2017 at 2:59 PM
and now Victoria/Genesis 8 is out. and yep crash test dummi
ProPose001 posted Thu, 15 June 2017 at 3:15 PM
yup. same here
diomede posted Thu, 15 June 2017 at 4:52 PM
I think I saw a post by Vyusur analyzing the new model (G8) and rigging. If I understood correctly, improvements in topology are minimum. Primary improvements are in weightmaps and rigging, which might not transfer to Carrara even if the figure loaded. Still, I'd probably buy a G8 character that could load in Carrara if it was similar to your Janette and Johnathon stuff and similar terms.
MistyLaraCarrara posted Thu, 15 June 2017 at 7:57 PM
saw the post!
her hd morphs wont do us much good 😾
she's A posed, does A pose give us a benefit?
looking under hood lol
MistyLaraCarrara posted Fri, 16 June 2017 at 1:08 PM
halfway there. not crashing and her shaping seems to be working. haven't tried them all.
MistyLaraCarrara posted Mon, 19 June 2017 at 11:42 PM
she's bending, blended weight rigging,
test driving her code name Veronica L8ke 🌠
DUDU.car posted Tue, 20 June 2017 at 3:53 AM
I'm actually impressed by your work, Misty! I think, thank to you, to jump in C8.5 (ask some royalties to DAZ3D!). Bravo!
MistyLaraCarrara posted Thu, 22 June 2017 at 12:54 PM
gettin there. :bouquet2:
testing her with the Vicki8 shape next.
MistyLaraCarrara posted Tue, 27 June 2017 at 10:49 AM
the Victoria 8 body morph is having an issue in rara :doh:
MistyLaraCarrara posted Sun, 02 July 2017 at 1:18 PM
here's a beta of the g8f preset.
i'm still stuck on the toes issue with the Victoria 8 fbm morph. 😿
Carrara Compatible Character Preset for Genesis 8 Female by MistyLaraPrincess
**Requires Genesis 8 Female Starter Essentials. Requires a version of Carrara supports Genesis
MistyLaraCarrara posted Wed, 05 July 2017 at 6:11 PM
the Ana Lucia character for g8f.
was a bit extra work to get the lingerie on her, besides converting to blended, had to transfer the Ana body morph to the clothes, used the ds transfer utility, then save it as a new product to save the morph transfer, it didnt save doing a save subset
Place display text here
MistyLaraCarrara posted Thu, 10 August 2017 at 12:48 PM
Olympia 8 having some troubles with 3 of the toes, not as severe as V8, but bad enough not to render her left foot shoeless.
also learned the make up is on pngs used with the DS lie.
Olympia's fiber eyebrows move with the pose controls. it doesn't come with any transferred morphs.
found transfering morphs from Olympia 8 to her eyebrows doesn't seem as tedious as i was afraid it would be.
the G8F eyelashes move with the pose controls, and comes with the base morphs, V8 and O8 morphs need transferring.
couple of corrective morphs on the toezeezes should do the trick.
