DocMatter opened this issue on Jul 21, 2017 ยท 11 posts
DocMatter posted Fri, 21 July 2017 at 9:04 AM
I notice that in the Figure drop down list, everything appears in order of when it was added to the scene, so the last things you added are at the very bottom of the list. A lot of times, when I have a more complicated scene, I add my main characters last after I set up the scene which puts them at the very bottom of the list. is there a way to rearrange items in this list so the ones I work with more often are at the top of the list? I have Poser Pro 11. Thanks!
Miss B posted Fri, 21 July 2017 at 11:15 AM
I use Netherworks' Scene Toy Pro sold at HiveWire 3D. It's a great little app that allows you to create groups and move things you want together into the same group. As an example, I have all my lights in a group, and all my cameras in a group. All clothing conformed, or parented, to a character, shows up listed together with the character. You can collapse each group you're not working with, so only the group you're interested in is fully expanded, and the Scene Toy window can be docked if you wish.
You can see it here --> http://hivewire3d.com/shop/shop-by-artist/netherworks-studios/scene-toy-pro.html
_______________
DocMatter posted Fri, 21 July 2017 at 11:48 AM
That looks awesome, but does it work on the Mac version of Poser? It doesn't say anywhere on the site.
adzan posted Fri, 21 July 2017 at 12:06 PM
DocMatter posted at 12:06PM Fri, 21 July 2017 - #4310348
Windows and Mac - the Mac should be OSX 10.4 or Higher
Miss B posted Fri, 21 July 2017 at 11:39 PM
Thanks for responding adzan, as I had to open the Guide to see if it was mentioned there. I'm going to get in touch with someone at HW and see if it can't be noted on the product page. I think the Contributing Artists write up all the information for such purposes, and he probably didn't think about it because he mentioned it in the Guide.
Of course, you can't get the Guide until you've actually purchased and downloaded the product. It would be helpful if Python script products mentioned they work with both Mac and Windows.
_______________
adzan posted Sat, 22 July 2017 at 3:04 AM
Miss B posted at 2:59AM Sat, 22 July 2017 - #4310402
Hi Miss B, Yes that's a good idea. When Joes' products were available at his own site and Runtime DNA I seem to recall that you could view the guides and or the readmes before you purchased the items, so it was easier to find out which software it worked with
stallion posted Sat, 22 July 2017 at 8:34 AM
This worked for me it will sort your library in alphabetical order "In poser.ini there is a setting called LIB_ITEMS_SERVER_SORT - set it to 1 This will sort items and folders in you runtimes in the library" hope this help
You might as well PAY attention, because you can't afford FREE speech
EClark1849 posted Sat, 22 July 2017 at 11:15 PM
I think Python is a cross platform language so it should work on all platforms, including OSX. If it doesn't work on a platform, it is because that system lacks a Python interpreter.
sandmarine posted Fri, 27 July 2018 at 9:20 AM
stallion posted at 9:18AM Fri, 27 July 2018 - #4310431
Everytime I change the 0 for a 1, the poser.ini file gets re-written with a 0 when I start Poser again. Any ideas how to fix this?
stallion posted Fri, 27 July 2018 at 5:16 PM
I found that there were two .ini files because poser place things in so many areas try the following Locate the Poser.ini
C:users - username - AppData - Roaming - Poser Pro - 11
Locate the line called
Setting it to 1 from 0 fixed the problem for me. the "AppData" folder may be hidden and you will have to unhide it
sandmarine posted Sat, 28 July 2018 at 5:05 AM
I finally fixed it, turns out my preferred scene was changing the 1 back to 0 everytime, so I created a new preferred scene after switching to 1, and now all's peachy. Thanks for the reply all the same!
