gmm2 opened this issue on Jul 27, 2017 ยท 4 posts
gmm2 posted Thu, 27 July 2017 at 4:03 PM
I'm working on a prop that is composed of five total props: a base, and four smart props. The base contains morphs for changing both its width and its height, and the smart props do not follow these morphs. They do follow the x, z, and y scales, but that's not what I want.
Is it possible to get these smart props to follow these morphs? I was thinking about a master parameter on the base to control both the x and y position of the smart props, or linking the existing morph dials on the base to such a thing.
pikesPit posted Fri, 28 July 2017 at 1:09 AM
I suppose it's some sort of cabinet with drawers tht you want to make, and you want to avoid that round knobs and the side walls of the drawers do deform when "scaling" You'll have to make separate morphs for the attached props too, and then link them to the master morph dials in the base.
Peter
gmm2 posted Fri, 28 July 2017 at 10:46 AM
pikesPit posted at 10:41AM Fri, 28 July 2017 - #4310874
Peter
So could that be done with a regular ERC control?
I'm also a bit wary about making morphs for the other props, since that might mess up their rotations. What I'm actually making is an MMA cage, and the doors for it need to follow the morphs I have to change the width and height of the main ring.
gmm2 posted Fri, 28 July 2017 at 1:02 PM
I tested adding ERC controls to one of the props, and it works the way I want. Just have to add the others now.
