Forum: DAZ|Studio
Subject: about rotate
atpo opened this issue on Aug 20, 2017 ยท 7 posts
atpo posted Sun, 20 August 2017 at 7:17 PM
RHaseltine posted Mon, 21 August 2017 at 9:53 AM
Which preset are you using in the import options? What was the model made in, if you know?
Jack238 posted Mon, 21 August 2017 at 10:27 AM
I think the question is can you change the center point of the rotate function and if so, how?
RHaseltine posted Mon, 21 August 2017 at 4:16 PM
Ah, sorry. You can use the Joint Editor tool to move the centre point (the green crosshairs)
atpo posted Mon, 21 August 2017 at 8:41 PM
Thanks. Model was made by pixologic sculptris alpha6. And x,x,z that how to be changed correctly in 'import parameter panel '? Because it always reverse.
RHaseltine posted Tue, 22 August 2017 at 3:49 PM
Try using the preset for 3D Studio Max, which also uses the opposite axis system from DS - if that gives the right orientation then you can adjust the scale, if needed, and save a new preset by clicking the button next to the scale box.
atpo posted Wed, 23 August 2017 at 7:16 PM
Thanks cat.
