Forum: MarketPlace Customers
Subject: Can't add item to cart
taoz opened this issue on Sep 07, 2017 ยท 4 posts
taoz posted Thu, 07 September 2017 at 12:10 AM
I'm getting an "Undefined" error whenever I try to add this item to the cart (no problem with other items):
https://renderosity.com/mod/bcs/?ViewProduct=119252
jennblake posted Thu, 07 September 2017 at 10:13 AM
Hi.
Our programmer said this is most likely a corrupted cookie. If you go to the vendor store page HERE and use the ADD TO CART green button directly under the thumb in the vendor's store, don't clck the thumb to go to the product page, it will add to cart for you. Then if you wanted...to just double check..you could delete it from your cart there. And then go to the product page and ADD to CART normally.
See if that works for you. 😄
taoz posted Thu, 07 September 2017 at 1:28 PM
That worked. Double checked and that worked too. Thanks! :)
jennblake posted Thu, 07 September 2017 at 2:00 PM
awesome! 😄
