Forum: Bryce
Subject: Cannot select object
atpo opened this issue on Sep 15, 2017 ยท 4 posts
atpo posted Fri, 15 September 2017 at 8:24 PM
TheBryster posted Sat, 16 September 2017 at 5:26 PM Forum Moderator
If the object is purple, then it is locked. Because you cannot select it to unlock it, you must first EDIT - SELECT ALL and then look for the icon tower and the [A]
Click on the [A] and uncheck Unlock in the menu box.
atpo posted Sat, 16 September 2017 at 7:53 PM
Copy that. Thanks.
StuartB posted Sat, 23 September 2017 at 6:24 AM
All objects can be selected even when Locked. Press the Tab key (the one with the left and right arrows on it on the left of the keyboard) This wil step through each object, you cant move the locked objects untill you click the "A" in the menu and untick the Locked button.
