Forum: Poser 11 / Poser Pro 11 OFFICIAL Technical
Subject: How do I prevent dynamic hair from cutting through skin?
starlingblue opened this issue on Dec 09, 2017 ยท 9 posts
starlingblue posted Sat, 09 December 2017 at 7:49 PM
Whenever I use Paulines dynamic hairs and run the smiulation, the hair cuts through the skin With both hairs, and with both bullet dynamics and legacy dynamics What can I do to prevent this?
Boni posted Sat, 09 December 2017 at 8:01 PM
I don't have Poser in front of me right now ... but you can turn on collision detection ... it works in both forms of dynamics. Keep in mind though to only use bullet physics on more distant animations because the collision barrier is more distant from the skin by its specific structure. Just be sure as I said to turn collisions on ... in a drop down menu that I can't pinpoint from memory. Sorry I don't have the details.
Boni
starlingblue posted Sat, 09 December 2017 at 8:22 PM
Collision was set on in all cases. The hair always cuts through the skin somewhere, on the forehead, cheeks, nose. Remade the animation several times with both hairstyles. The animation is rather slow, its a soft head up-down movement that takes 180 frames.
starlingblue posted Sat, 09 December 2017 at 9:14 PM
Here you can see it cutting through forehead and nose.
It always happens, with both methods and all hairs of Pauline.
Is there a character where dyanmic hairs actually work? I have Poser 11 standard, not pro.
Or is it just a bug with this software ? - if so dynamic hair is unusable.
I am surprised no one else has noticed so far.
RedPhantom posted Sat, 09 December 2017 at 9:21 PM Site Admin
There are 3 places where you have to turn on collisions. 1 is for the figures you want to collide with the hair. 2 is for the hair groups. 3 is for the whole scene. The hair also needs to have enough vertices and not start inside the figure. It still isn't a guarantee. Legacy works better than bullet but neither work perfectly.
starlingblue posted Sat, 09 December 2017 at 9:30 PM
Ok thanks
Where do I turn collision for the figure and for the scene on?
starlingblue posted Sat, 09 December 2017 at 9:39 PM
Ok, I found it, thanks.
RedPhantom posted Sat, 09 December 2017 at 9:40 PM Site Admin
here is the same hair with legacy draping
starlingblue posted Sat, 09 December 2017 at 9:42 PM
Thanks again
