Forum: DAZ|Studio
Subject: How do you rotate around an object ?
exxe opened this issue on Dec 18, 2017 ยท 4 posts
exxe posted Mon, 18 December 2017 at 10:11 PM
Jack238 posted Tue, 19 December 2017 at 2:01 PM
Objects can be rotated in a few different ways. So I would suggest trying them to see what suits your needs best. First, in the Parameter Tab, under the General Item will be a list of transforms. Rotation can be accomplished there. Also, under Tools on the Menu Bar is the Rotate Option (The Rotate Widget will appear in the Viewport), and the Universal Option (which displays a widget in the Viewport to do Transform operations including Rotate) Also there is the keyboard short cut (Alt-Shift-R) which displays the Rotate Widget.
Hoe that helps and gets you started. Jack238
RHaseltine posted Tue, 19 December 2017 at 2:41 PM
See your other thread if you mean you want o orbit the camera about an item https://www.renderosity.com/mod/forumpro/?thread_id=2920141
satria posted Sun, 31 December 2017 at 1:26 AM
For Tweaking purpose or animation ? for tweaking pose - morph or expression try "ctrl"alt+LMB" . Here useful video about shortkey[DAZStudio Shortkey tips] https://www.youtube.com/watch?v=MiJXI-pshrc)
