smallspace opened this issue on Dec 20, 2017 ยท 9 posts
smallspace posted Wed, 20 December 2017 at 1:21 PM
As soon as I launch the script, Poser crashes and closes.
I'd rather stay in my lane than lay in my stain!
Kazam561 posted Wed, 20 December 2017 at 7:41 PM
I don't know if PhilC's updated it but usually he's very good about free updates. I'd contact him through the store, or through his website.
The dust settled, thinking "what a fine home, at least for now" not realizing that doom would soon be coming in the form of a vacuum cleaner.
Boni posted Thu, 21 December 2017 at 7:34 AM
You can also contact him through facebook, he posts regularly there.
Boni
NanetteTredoux posted Thu, 28 December 2017 at 2:01 AM
I am having the same problem with Poser Toolbox and Poser Pocket Knife
Poser 11 Pro, Windows 10
FVerbaas posted Thu, 28 December 2017 at 9:08 AM Forum Coordinator
Did it work on Windows10 before? Did you changfe location of Runtimes? I found win10 less sloppy in access rights than win7 and before were. That is a good thing, but old school organisation like writing into a runtime in the program files folder may not work. Poser itself has solved this but of course older plug-ins can still rely on yesterday's innocence. Try to run Poser as administrator. This is not a good permanent solution but it may help you out on occasions.
NanetteTredoux posted Fri, 29 December 2017 at 1:12 AM
Running Poser as administrator does not solve the problem. It worked on Windows 10 before. But obviously, Windows has updated itself several times since then.
raven posted Fri, 29 December 2017 at 5:20 AM
I don't have Windows 10, I use 7. Poser Tool Box crashes my PoserPro11.1 on my machine too, but is still working in PoserPro11 sr8.
Khai-J-Bach posted Fri, 29 December 2017 at 3:33 PM
More than likely the new poser update has a new python version, meaning that the toolbox will need to be recompiled to work.
(infact 99% certain this is the issue.. We've seen it happen before with poser upgrades and patches....)
FVerbaas posted Sat, 30 December 2017 at 10:45 AM Forum Coordinator
Khai-J-Bach posted at 5:36PM Sat, 30 December 2017 - #4321214
More than likely the new poser update has a new python version, meaning that the toolbox will need to be recompiled to work. (infact 99% certain this is the issue.. We've seen it happen before with poser upgrades and patches....)
Unlikely: Poser 11.1 uses Python version 2.7.1 (r271:34759, Dec 13 2017, 03:10:36) [MSC v.1800 64 bit (AMD64)] Poser 11 used 2.7.1 also, but of course earlier build. Changes should not lead to the effects reported.
