bjbrown opened this issue on Jan 13, 2018 ยท 6 posts
bjbrown posted Sat, 13 January 2018 at 4:01 PM
I have made an eye-shaped trinket model in Blender. The front edge of the eye is supposed to be flat. However, one corner appears to slightly bulge out, while the other corner appears to dent inwards. I tried marking the affected edges sharp, but that did not seem to help. What is happening and how do I fix it? Attached is a picture showing the model in Blender and then displayed in Poser.
LuxXeon posted Sat, 13 January 2018 at 4:19 PM
Are you sure the vertices that join in those corners welded properly?
______________________________________
My Free Models
My Video Tutorials
My CG Animations
Instagram: @luxxeon3d
Facebook: https://www.facebook.com/luxxeon
Lobo3433 posted Sat, 13 January 2018 at 4:31 PM Forum Moderator
Prior to importing to Poser did you all your modifiers? If not I would look for verts that are not welded properly like LuxXeon mentions above
Lobo3433
Blender Maya & 3D Forum Moderator
Renderosity Blender 3D Facebook Page
bjbrown posted Sun, 14 January 2018 at 4:11 PM
Everything seems welded properly. The Blender export options I have checked are: Apply Modifiers, Include Edges, Write Normals, Include UVs, Write Materials, Objects as OBJ Objects. Importing into Poser I checked only Centered and Place On Floor.
Playing with grouping tools in Poser, I was trying every option with which I was not familiar. Using "Create Perspective UVs" fixed the problem.
However, I don't know what "Create Perspective UVs" actually does, or what specific problem it seemed to fix.
Lobo3433 posted Sun, 14 January 2018 at 4:52 PM Forum Moderator
I normally do not recommend paid products or tutorials since Blender is free but where Poser is concerned this product that is in our market place here and I happen to own it so I can personally recommend has allot of information about settings in Poser when deal with models imported from out side programs most are general modeling techniques you can use across different software and adjustments with in Poser that you may need to do so it looks right and currently it is on clearance price Modelling for Poser Both Poser and Daz Studio have their own oddities that make a model that is imported look wrong no matter that the model is perfectly fine. I know this might not fully answer your question but it is the best I can recommend. I also recall someone mentioning that at times Tris work better in Poser than Quads but I think that was truer for older versions of Poser And on a final note you can Create Perspective UVs in Blender I have seen free tutorials on that on Youtube
Good Luck
Lobo3433
Miss B posted Sun, 14 January 2018 at 9:48 PM
Oh, thanks for the tutorial link Lobo. I just went to check it out, and it's on sale for a very reasonable price.
_______________
