gojira-kun opened this issue on Jan 13, 2018 ยท 12 posts
gojira-kun posted Sat, 13 January 2018 at 6:23 PM
I'm using Poser Pro 2014. How do I render a Flat Lined character in full resolution? When I use "Export image" it creates a screen resolution (72 dpi) image. Is there some option in Render Settings to export the Flat Lined character I see on the screen as a 300 dpi image for print?
SamTherapy posted Sun, 14 January 2018 at 8:32 AM
As far as I know, Poser still uses absolute sizes - pixels - which do not relate in any way to dpi. You'll have to do the necessary calculations to render an image for conversion to 300 dpi. For example, a 300 x 300 image will equate to 1 inch square - 25.4 mm - at 300 dpi. Work out your desired size in inches, multiply by 300, render at that size.
ThunderStone posted Sun, 14 January 2018 at 8:41 AM
@SamTherapy, thanks for the tip.
OS: Windows 11 64-bit
Bryce: Bryce Pro 7.1.074
Renderer: Superfly, Firefly
9/11/2001: Never forget...
Digitell posted Sun, 14 January 2018 at 8:42 AM Forum Coordinator
Not sure what you mean by flat lined. If you mean to put a toon line around an image then you would do this under Render>Settings:
To render at 300 DPI that would be under Render>Dimensions:
Hope this helps!
SamTherapy posted Sun, 14 January 2018 at 10:53 AM
Well, how about that? Shows how long since I played with the render settings. I just render at "Bloody Enormous", then crop and resize as necessary.
Digitell posted Sun, 14 January 2018 at 10:58 AM Forum Coordinator
Hi Sam! The resolution can be set in Render>Render Dimensions
The Render Settings is where you can select the toon outline
Glad this helps!
gojira-kun posted Sun, 14 January 2018 at 11:09 AM
Thanks for everyone's help. Sorry I wasn't clear in what I was looking for. What I wanted was this. I set up a figure and set Display/Figure Style to "Flat Shaded Lined." That gave me:
What I wanted was to get the same effect in my render, a shaded white figure with a grid all over. Anyway I discovered the answer and it was ridiculously simple. In render settings I chose the "Preview" tab and the "Render Now (Firefly)" button turned into "Render Now (Preview)." Press the button and I got what I wanted.
Digitell posted Sun, 14 January 2018 at 11:14 AM Forum Coordinator
SamTherapy posted Sun, 14 January 2018 at 11:49 AM
If you want a true render, you can create a UV template (UVMapper is free for the regular version) and place that on your figure. The figure can then be used in any normally rendered scene.
@digitell - yep, I meant "Render Dimensions". I shouldn't type while talking to small children.
Digitell posted Sun, 14 January 2018 at 12:26 PM Forum Coordinator
SamTherapy posted at 12:25PM Sun, 14 January 2018 - #4322209
@Sam - LOL...Quite understandable!
SamTherapy posted Sun, 14 January 2018 at 3:17 PM
digitell posted at 9:14PM Sun, 14 January 2018 - #4322212
It goes something like this:
"Daddy, look at this picture I drew of Carmen (one of our cats) knocking over your guitar and can you tell Ilona to stop looking at me in that funny tone of voice and Mummy says if you don't move your toolbox she's going to shove it up your bottom and can I have an ice cream please?"
"Yes, that's lovely... WHAT!?"
Digitell posted Sun, 14 January 2018 at 3:22 PM Forum Coordinator
"It goes something like this:
"Yes, that's lovely... WHAT!?""
OMG...that is sooo friggin hilarious!!!! And cute too!! Big Fun!!! LOL!! Sounds like you have a fun "Entertainment Center"! A good time was had by all!
