Forum: MarketPlace Customers
Subject: Double posts images galleries
Pepsel opened this issue on Mar 24, 2018 ยท 10 posts
Pepsel posted Sat, 24 March 2018 at 8:45 AM
Hi everybody, i am new at posting images into the gallery, and before i knew, there where three of the same posts (renders)into the gallery from the character of the vendor i used with that render. I clicked on the red Delete button to delete two of these renders, but nothing happened. I don't want my triple renders to go allover that gallery, just one is enough :D Do you know how i can delete them anyway? Thanks very much :D
jennblake posted Sat, 24 March 2018 at 11:34 AM
Hi. I only see 2 images in your gallery. 😄 It look like you may have fixed it. 😄 Don't worry...you'll be a pro in no time at all. Beautiful work!!
Pepsel posted Sat, 24 March 2018 at 11:38 AM
HiJennblake, thank you so much for the fast answer:D The problem is the render from Savannah from MDD ; that is placed several times in the gallery from that character,about four times now, and i wanted to delete them untill just one is in that gallery. Four times is a bit to much :D
Pepsel posted Sat, 24 March 2018 at 11:39 AM
And thank you for the compliment 😁
Miss B posted Sat, 24 March 2018 at 11:48 AM
Hi Pepsel, I just checked your gallery, and there's only two renders in it, Savannah and Oomi. Are you talking about the Product Credit thumbnails for the products you used to create the Savannah render? If that's the case, those show up when you use the Gallery software to list the credits. I used to do that years ago, but when the Gallery software changed, I started just listing them by typing the information in the Description area when I uploaded a number of renders last year. If that's what you're referring to, that's not an error. If you're seeing 3 or 4 of your Savannah render, then I'm not sure what the issue is, as I'm not seeing more than one of your render.
BTW, very nice work on both renders. 🙂
_______________
Butterfly Dezignz
Pepsel posted Sat, 24 March 2018 at 11:53 AM
Thanks Miss B 😁 The case it, when you go to the product page of Savannah, and then go to the gallery of that product,you can see four renders of Savannah in it. A little bit to much 😂 I can see the red delete button on those renders, so i wanted to delete all the others exept one, but nothing seem to happen, so there are still four there...
jennblake posted Sat, 24 March 2018 at 3:00 PM
I'll get that checked out for you. Won't be until Monday when the programmer comes back in. But we will look at it. 😄
Miss B posted Sat, 24 March 2018 at 6:46 PM
Pepsel posted at 7:45PM Sat, 24 March 2018 - #4326735
Ahhh, I misunderstood. I thought you were talking about your Gallery page, when you were referring to the Gallery page for the product. OK, I didn't check that out.
_______________
Butterfly Dezignz
Pepsel posted Sun, 25 March 2018 at 10:39 AM
Thanks Miss B. 😄 Maybe i will find the solution for this problem soon, i hope 😆
Pepsel posted Wed, 28 March 2018 at 8:08 AM
Hi JennBlake, i saw that you removed all the images i had posted to much, thank you so very much for that!! 😁
