Forum: Poser 11 / Poser Pro 11 OFFICIAL Technical
Subject: I got a really really bad problem . .this is from a fresh install Poser11.1
akura_ opened this issue on Apr 28, 2018 ยท 9 posts
akura_ posted Sat, 28 April 2018 at 11:05 AM
Can I please get some help. I just got this last week. Whats more when ever I try using any of my already added in ones. my windows7 comes back and tells me their not valid win30 applications.
ironsoul posted Sun, 29 April 2018 at 11:33 AM
Was the install done by the Download Manager of another method?
Is this on a 32bit or 64 bit version of Windows?
Could the runtime in \Program Files\Smith Micro\Poser 11 have been changed by something done after the install?
Might be worth checking to see where wxPython is being loaded.
Open "Python Shell" from Scripts menu
Into the window opened enter the command
print wx.(underscore)(underscore)file(underscore)(underscore)
Replace (underscore) with the underscore character on your keyboard.
akura_ posted Sun, 29 April 2018 at 1:32 PM
only method was the Download manager you get from the shop and it was 32bit as the 64 bit would not install.
ImportError: DLL load failed: %1 is not a valid Win32 application. ImportError: DLL load failed: %1 is not a valid Win32 application. ImportError: DLL load failed: %1 is not a valid Win32 application. Traceback (most recent call last):
what i get when i opened the Python Shell
ironsoul posted Sun, 29 April 2018 at 4:44 PM
It would appear the shell uses wx so we're a bit stuck on how to run Python to get the version.
numpy has compiled components and doesn't like mixing 32bit and 64bit libraries so it could be the build installed doesn't match the OS for some reason. If your Win 7 is 64 bit its strange you can only install 32bit Poser. I would raise this with Smith Micro support.
hborre posted Mon, 30 April 2018 at 11:06 AM
Upon the initial install, you are also given a choice to install the 32-bit version alongside the 64-bit issue. The purpose is to allow the users to run 32-bit dedicated Python scripts which cannot run under 64-bit. Strange that the claim 64-bit would not install from Download Manager, but clearly the application is screaming not a valid 32-bit application.
akura_ posted Wed, 02 May 2018 at 11:12 AM
hborre posted at 11:11AM Wed, 02 May 2018 - #4329216
in fact it failed to install the 64 bit :( why i had to go back to install the 32 one. yes i'm running 64 bit version of win
ypvs posted Fri, 04 May 2018 at 5:40 PM
Have you uninstalled and re-installed P11? Maybe a corrupted download or even HD fault? It might be worth deleting you downloads and setting Download manager to use another folder
Poser 11 , 180Gb in 8 Runtimes, PaintShop Pro 9
Intel Q9550 Quad Core cpu,  16Gb RAM, 250Gb + 250Gb +160Gb HD, GeForce GTX 1060
akura_ posted Sat, 12 May 2018 at 8:48 AM
that the thing its not exactly installed to my pc. its on a 1 tb flash book D: i checked to see if it was having issues but when i installed it . it removed everything already installed. so why am i still getting this. btw i downloaded the expatiation update the SR 8 stuff from the download manager. was i suppose to do something with the files in the folder it made ?
akura_ posted Sat, 12 May 2018 at 1:52 PM
ImportError: DLL load failed: %1 is not a valid Win32 application. ImportError: DLL load failed: %1 is not a valid Win32 application. ImportError: DLL load failed: %1 is not a valid Win32 application. ImportError: DLL load failed: %1 is not a valid Win32 application. ImportError: DLL load failed: %1 is not a valid Win32 application. ImportError: DLL load failed: %1 is not a valid Win32 application. Traceback (most recent call last): Traceback (most recent call last):
when ever i try using any pythons :( here what my folders look like. dont.JPG
