taiuri opened this issue on May 29, 2018 · 28 posts
taiuri posted Tue, 29 May 2018 at 5:31 PM
Hi Guys! I have a problem importing G3M Clothes into Poser Pro 2014/11. I followed the procedure I attach (first export it as an obj file in the Geometry Folder from Poser Runtime and after export it as a cr2 file in the Characters Folder from the Poser Library). When I load and conform it, it seems to be correct, but when I try to move the Figure, the cloth stays in the same place and it gets distorted like I show in the pictures attached.
I have to say I don't have this problem when I export G2 Clothes in Poser. These ones are G3M clothes autofitted to a G2M Figure, thanks to the Autofit Plugin. In Daz Studio it's fitted correctly, the problem is in Poser when it's exported.
Could you help me guys?
RobZhena posted Tue, 29 May 2018 at 6:05 PM
I didn’t think you could export G3 items as cr2’s to Poser because the rigging is different, unless you use Willdial’s utility. G2 cr2’s convert fine I’m Poser.
taiuri posted Tue, 29 May 2018 at 6:25 PM
In the 2016, I got to do it successfully, the problem is my pc crashed and when I reinstalled all my programs, I have these results. My frustation is knowing before I could get it and now I can't.
RobZhena posted Tue, 29 May 2018 at 7:16 PM
Do you change the cr2 to point to the obj? I'm pretty sure I tried that without success, but maybe I'm wrong.
taiuri posted Tue, 29 May 2018 at 7:24 PM
I just followed the same procedure I did before, which it's explained in the screencaps, previously I can do it without problems, but now I have this issue. I've tried everything, but I have the same result. :(
Nails60 posted Wed, 30 May 2018 at 5:34 AM
I've never tried this on imported genesis 3 clothing but maybe you could just run it through the fitting room. When I have problems with content not conforming properly or moving correctly I just take it into the fitting room (together with the character) don't actually run a fitting session just create a character including regrouping.
RedPhantom posted Wed, 30 May 2018 at 6:31 AM Site Admin
Try copy joint zones in poser.
infinity10 posted Wed, 30 May 2018 at 12:33 PM
I am guessing that the autofit from G3 to G2 is not being correctly translated. Can you import just the OBJ into Poser and see if the shape is G2 ? If not, then I suspect that the autofit magnets or whatever technology DS is using, has not been passed over to the Poser-compatible CR2.
Eternal Hobbyist
jeffnlkpt2 posted Wed, 30 May 2018 at 1:27 PM
What I do is do an autofit in DAZ and then save the object as a figure asset. I then create a poser companion file with DSON. I have converted a lot of clothes this way and has never had an issue.
taiuri posted Wed, 30 May 2018 at 3:22 PM
Nails60 posted at 3:22PM Wed, 30 May 2018 - #4330819
I tried, unfortunately it didn't work :(
taiuri posted Wed, 30 May 2018 at 3:23 PM
RedPhantom posted at 3:23PM Wed, 30 May 2018 - #4330820
Could you explain me how to do that, please?
taiuri posted Wed, 30 May 2018 at 3:26 PM
infinity10 posted at 3:24PM Wed, 30 May 2018 - #4330869
When I import the cloth, it looks bigger than the figure, but if I conform, it fits correctly, the problem is the traslation like I showed in the pictures attached :(
taiuri posted Wed, 30 May 2018 at 3:38 PM
jeffnlkpt2 posted at 3:37PM Wed, 30 May 2018 - #4330875
I tried, but it didn't work :(
taiuri posted Wed, 30 May 2018 at 4:09 PM
RedPhantom posted at 4:09PM Wed, 30 May 2018 - #4330820
I tried it and didn't work either :(
taiuri posted Wed, 30 May 2018 at 5:27 PM
Any other idea guys?
RedPhantom posted Wed, 30 May 2018 at 6:34 PM Site Admin
you might try adjusting the weight maps or inner matspheres (depending on how the figure is rigged) with the joint editor window.
taiuri posted Wed, 30 May 2018 at 7:03 PM
RedPhantom posted at 7:02PM Wed, 30 May 2018 - #4330891
I tried and neither i worked :( There is something that Daz is not exporting to Poser, but what? what could it be?
taiuri posted Wed, 30 May 2018 at 7:26 PM
This really strange, if I export directly the G3M Figure and his cloth to Poser, it's not exported complete:
Could you do a favor? If you have Daz Studio, Poser and Genesis 3 Figures and some G3 Clothes, could try to export it to Poser following the method I explained before and tell me your results please? Problably it must be a Plugin or something like that I need for Poser.
I'll be waiting your results. Thank you guys.
infinity10 posted Wed, 30 May 2018 at 10:49 PM
jeffnlkpt2 posted at 11:47AM Thu, 31 May 2018 - #4330875
Theoretically, this seems the correct methodology. Also, I suspect one issue with all solutions not working is to start with a new scene. poser memory gets very bad when the same scene is used to re-import Daz Studio content either via ObJ and CR2 or by DSON.
Eternal Hobbyist
taiuri posted Thu, 31 May 2018 at 3:41 PM
infinity10 posted at 3:40PM Thu, 31 May 2018 - #4330894
Could you try by yourself in your pc and let me know if you have this issue too. I have to know if the problem is general or only mine.
taiuri posted Thu, 31 May 2018 at 7:24 PM
If I create a DSON for the Figure and the Clothes, it worked, but I prefer the Cr2 Exporter method. I don't like to import them through DSON. Could someone here try to export a Genesis 3 Figure to Poser by the Cr2 Exporter Method please? I need to know if the problem is general or only mine.
taiuri posted Sat, 02 June 2018 at 9:26 PM
So guys? Did you get to export them in Poser using the Cr2 Exporter successfully?
FVerbaas posted Sun, 03 June 2018 at 2:07 AM Forum Coordinator
The one thing I have not heard mention in this discussion is Fitting Room. That would be the tool of choice for this operation.
taiuri posted Sun, 03 June 2018 at 1:44 PM
FVerbaas posted at 1:44PM Sun, 03 June 2018 - #4331029
I tried with the Fitting Room too and it didn't work :(
taiuri posted Sun, 03 June 2018 at 2:09 PM
A friend told me the problem the clothes get distorted is a bone binding problem and it's necessary to synchronize pants and body bones, but I don't know how to do it Poser. Do you know something about how to do it? Could you explain me guys, please?
FVerbaas posted Sun, 03 June 2018 at 2:38 PM Forum Coordinator
taiuri posted at 9:34PM Sun, 03 June 2018 - #4331064
That is odd. Did you use the AutoGroup function?
taiuri posted Sun, 03 June 2018 at 3:52 PM
FVerbaas posted at 3:52PM Sun, 03 June 2018 - #4331067
Yes, I did :(
taiuri posted Mon, 04 June 2018 at 1:50 PM
