Subject: I have a problem creating a Smart Prop
Stevenb3D opened this issue on May 11, 2001 ยท 8 posts
Stevenb3D posted Fri, 11 May 2001 at 10:27 AM
Posette is doing her part for the war effort by helping guide RAF pilots to intercept Jerry or is that "Gerry". Anyway she is having a problem with her headset. I've created a very basic model of a headset. I want to make it into a smart prop. I followed the directions in the poser manual but it doesnt seem to work for some reason. I import my headset as an obj object, move it into position and parent it to the head. I then do the follow try and create a smart prop. 1)Open the Prop palette 2)Click on Add to library (+) 3)I click on Select Subset to select the headset object 4)Name the prop and click OK The manual says that if your prop has a parent element, a popup box will appear asking if you want to create this as smart prop. I never get this popup box. It just saves the prop. Is there something Im leaving out? I set the parent of the headset to posette head before I start the prop saving process. I have also noticed something else that is strange. I click the Select Subset button and in the Hierarchy Selection I select the headset object. I click OK and if I go back in by clicking the Select Subset again, I notice the headset is no longer selected. Does anyone have any advice?
