Nod opened this issue on Jun 08, 2018 ยท 10 posts
Nod posted Fri, 08 June 2018 at 7:57 PM
I've been having a weird problem with Poser 11.1 Pro. When installing a file, the item in question isn't showing up in the Poser directory. This applies to installing the ZIP via the built in extractor, or doing it the old fashioned way and installing straight to the Runtime folder from the ZIP itself. If I use explorer, I can see the files happily sitting there in the appropriate folders, so it's not like they're in the wrong directory. It's just that Poser can't see them, not even with a search.
The weird part is that if I install them into Poser 9 using the exact same method, they'll show up in the Poser 9 Runtime which I have set up in Poser 11.
I've installed 100s of Zips and this has only happened with Poser 11. Any ideas?
