Subject: How do you combine two light sets in the same scene?
trentsol opened this issue on Jun 22, 2018 ยท 4 posts
trentsol posted Fri, 22 June 2018 at 10:20 PM
Wanting to combine the light set for inside a store model (Boutique/Shop by 3-D-C ) and the daylight light set from outside shining into the store. Working with Poser 9 (aka Poser Pro 2012) . Hopefully it wont be too bright lit all at once, but willing to dim the lights inside. The outside lights are a sunrise-type set, and very bright at that.
infinity10 posted Fri, 22 June 2018 at 11:55 PM
click on the double tick in your library panel
Eternal Hobbyist
Kazam561 posted Sat, 23 June 2018 at 11:30 AM
The two checkmarks add to a scene, the single check mark replaces the item in the scene. If the two lights sets end up too bright, you can chose a single light (in a set) and adjust it under it's parameters and it's properties.
The dust settled, thinking "what a fine home, at least for now" not realizing that doom would soon be coming in the form of a vacuum cleaner.
trentsol posted Sat, 23 June 2018 at 4:17 PM
Thanks fellas. Looks simple enough.
