AnyMatter opened this issue on Jul 15, 2018 ยท 12 posts
AnyMatter posted Sun, 15 July 2018 at 7:08 PM
hi members, please look at the image below, the object is a smooth 3dmodel at 1st, once skeleton applied and weight mapped, unwanted dark spots show up around the model... any idea how to fix it?
rokket posted Sun, 15 July 2018 at 10:33 PM
Do they render like that? If not, then don't worry about fixing it
AnyMatter posted Sun, 15 July 2018 at 11:17 PM
greetz rokket,
same thing happened ,rendered in firefly ...poser 10
rokket posted Mon, 16 July 2018 at 8:07 AM
Poser 10? Try to add subdivision and see what happens. If it's the same, I am at a loss...
AnyMatter posted Mon, 16 July 2018 at 9:19 AM
my goat... worked like a charm ,need no subdivision though, just change skinning method from traditional to unimesh. rokket,..thanks very much for the help!
SamTherapy posted Mon, 16 July 2018 at 2:16 PM
I wonder if they are unconnected polys or Ngons. They sometimes render like that.
AnyMatter posted Mon, 16 July 2018 at 3:34 PM
yeah, i did suspect they are unconnected polys after setting up figure bones in setup room. 1 thing is that if i save it to figure library, poser will create a new identical geometry file obj in that library folder, but with seams visible around it like it was group separated or somtng.
rokket posted Mon, 16 July 2018 at 8:22 PM
I never would have thought about ngons. And I've only seen unconnected polys destroy a cloth sim. I guess Poser's smoothing and crease angle will expose modeling issues. Glad you fixed it.
CHK2033 posted Mon, 16 July 2018 at 8:37 PM
AnyMatter posted at 8:32PM Mon, 16 July 2018 - #4333241
Maybe it did check wait.... check his vid it may help https://www.youtube.com/watch?v=YikiP9pEAp4
HP Zbook 17 G6, intel Xeon 64 GB of ram 1 TB SSD, Quadro RTX 5000
rokket posted Mon, 16 July 2018 at 10:06 PM
If you change the view in the main window to wire frame, that ngon will be visible. You will have to tessellate it into a quad.
CHK2033 posted Mon, 16 July 2018 at 10:54 PM
rokket what the hell man lol did you ever finish those wings?
rokket posted Tue, 17 July 2018 at 7:38 AM
TheDarkerSideOfArt posted at 5:37AM Tue, 17 July 2018 - #4333257
Yeah, but they are on my laptop and I am forced to surf the web on the company's computers. So I can't post them...
