persius opened this issue on Sep 17, 2018 ยท 3 posts
persius posted Mon, 17 September 2018 at 6:07 PM
I am new to Vue and I have run into a problem that I can't resolve. When I create terrain and enter the "terrain editor" I notice what appears to be two terrains over top of each other and I can't work with them. I've attached a screen shot to illustrate what I see every time. I also noticed that I'm unable to use the "reset" option. Most of the time it's grayed out and when it is active and I select it, nothing happens to the terrain!
If somebody could please offer a suggestion as to what is happening here I would appreciate hearing from you.
martial posted Wed, 19 September 2018 at 3:39 PM
I just try to reproduce this in Vue infinite 2016 I think is the clipping plane when you are in the terrain editor in the terrain editor , at the top, you have somes icons . the icon called show clipping plane is probably actived ; click on to desactive
persius posted Fri, 21 September 2018 at 11:44 AM
Hi I did try as you suggested but nothing has changed. I'm guessing this is how my version of Vue works. Thanks
