arrow1 opened this issue on Jan 09, 2019 · 22 posts
arrow1 posted Wed, 09 January 2019 at 2:11 PM
Poser update is now available in Smith Micro Download Manger.Not sure quite sure what it does update! Cheers
Custom built computer 128 gigs RAM,4 Terabyte hard drive, NVIDIA RTX 4060 TI 16 GIG Gig,12 TH Generation Intel i9, Dual LG Screens, 0/S Windows 11, networked to a Special 12th Generation intel I9, RTX 3060 12 Gig, Windows 11,64 gigs RAM, Dual Phillips Screens, 2 Terabyte SSD Hard Drive plus 1 Terabyte Hard Drive,3rd Computer intel i7,128 gigs ram, Graphics Card NVIDIA RTX 3060 Gig,1 Terabyte Hard Drive, OS Windows 11 64 Bit Dual Samsung Syncmaster 226bw Screens.Plus INFINITY Laptop 64 Bit,64 gigs RAM.Intel i9 chip.Windows 11 Pro and Ultimate. 4 x 2 Terrabyte Hard Drives and 2 x 2 Terrabyte external USB Hard drives. All Posers from 4 to Poser 2010 and 2012, 2014. Poser 11 and 12, 13, Hexagon 2.5 64 Bit, Carrara 8.5 Pro 64 bit, Adobe Photoshop CS4 Creative Production Suite. Adobe Photoshop CC 2024, Vue 10 and 10.5 Infinite Vue 11 14.5 Infinite plus Vue 15 and 16 Infinite, Vue 2023 and 2024, Plant Catologue, DAZ Studio 4.23, iClone 7 with 3DXchange and Character Creator 3, Nikon D3 Camera with several lenses. Nikon Z 6 ii and Z5. 180-600mm lens, 24-70 mm lens with adapter.Just added 2x 2 Terrabyte portable hard drives.
Kenmac posted Wed, 09 January 2019 at 2:31 PM
This was posted by Miss B over on the Hivewire 3D forum:
"Poser 11.1.1 Enhancements and Fixes by Category
General • Removed Facebook sharing. • “Drop to Floor” in Setup Room is no longer disabled. • User is now alerted of an error when trying to delete a camera in Python scripting. • Removed the “Reopen Folders Toggle” option from the content Library tab. • Improved visibility of time range text boxes in the Make Movie window. • Right click context menu of an object now only shows “Conform To…” command when relevant. • ImportOptions now constructs proper options for Weld Groups. • Implemented a new camera property to convert camera orbit values between the limits of -360, 360. • Altered the Render and Movie Settings window. • The Load Preset is disabled if FireFly or SuperFly have no presets in the User or App preset folder. • The Delete preset is dsabled if FireFly or Superfly have no Presets in the user preset folder. • Hovering over the Load Preset, Delete Preset, and Render Dimensions now produce a help text tag. • Removed “Send Render To” button • When a light in the Light Control widget is selected it can now be deleted with the DELETE key. • Red circle in the setup room can now be removed via Display -> Figure Circle
Content • Content Updater now provides Paulina/Paul 2. Queue Manager (Pro Only) • The correct Queue Manager Node installer is now available via Download Manager • Queue Manager now properly invokes FFRender
Bug Fixes • Poser no longer crashes when using Auto Generate Colors button in Flash Export option. when making custom color quantizations. • Poser no longer crashes when changing to Preview Rendering when auto-generating colors for the Flash Options Dialog. • Poser no longer crashes when “DeleteAllLights” is used. • Prop name now properly displays on the Parameter Dials. • 3D Path Palette is now shown in the German and Japanese version. • Poser no longer crashes when Optimize Simple Materials is turned on. • Fixed defect in 3D Paths “second path” not working properly when copy/pasted. • Fixed defect where 3D path stays selected and blocks the use of keyboard shortcut to toggle the scene."
operaguy posted Wed, 09 January 2019 at 2:40 PM
I wonder what this helps ... recently I've been attempting to convert conforming clothing into dynamic by exporting/importing .obj, but the models seem to fall apart during simulation calc, no matter what group editing I try, including "weld group."
Miss B posted Wed, 09 January 2019 at 2:46 PM
One thing that list I found on the SM Poser Forum doesn't mention is, folks who had updated the last couple of Service Releases had been having problems when clicking on Universe in the Hierarchy Editor, as it would crash Poser. From some of the comments I've seen on that forum the past couple of days, it's also been fixed.
_______________
vitachick posted Wed, 09 January 2019 at 4:25 PM
I opened D/L mgr and no updates shown. I have two serial numbers listed...Shows I have version 10.0.52895
Win10 Poser 2014/Poser 11 Daz3D
randym77 posted Wed, 09 January 2019 at 5:14 PM
All the Poser content has the new version number, too - animals, figures, etc. Should I download those, too?
vitachick posted Wed, 09 January 2019 at 6:39 PM
Why don't I have this upgrade??? Grrrrrr
Not for nothing but Poser 2014... It is now 2019...Wish they would update and get with the calender year???
Miss B posted Wed, 09 January 2019 at 7:57 PM
@vitachick This update is for those using Poser 11 or Poser Pro 11, not an update for Poser 2014.
_______________
mackis3D posted Thu, 10 January 2019 at 12:22 AM
@vitachick: I still use Poser Pro 2014 besides PP11. Is there something with PP2014 that needs to be updated? I think it's very stable.
FVerbaas posted Thu, 10 January 2019 at 1:48 AM Forum Coordinator
operaguy posted at 8:33AM Thu, 10 January 2019 - #4343371
The issue solved is in the Python interface. The welded import in the user interface worked and was not changed. If a certain geometry you imported manually does not appear 'welded', the vertex arrangement may be such the vertices cannot be welded.
The advantage of the update is that you can now have a Python script that can export a welded mesh. It is not fast because it involves saving as a prop, reload welded, and then save out the welded prop, but at least it is something.
The fix was made following a report by yours truly. Tomorrow I will check out the test script I provided to SM at the time and post it over the weekend because it may be of interest to others.
It will also be part of the MDBridge to Poser. MD can deal with un-welded meshes but it needs a welded mesh of the avatar if you want to draw lines on the avatar and trace patterns from it.
jartz posted Thu, 10 January 2019 at 2:17 AM
I'm with randym77. What do you download - the updates or the installers? Could I just download only the update on the Updates tab or do I have to download all from the Installers?
____________________________________________________________________________________________________________________________
Asus N50-600 - Intel Core i5-8400 CPU @ 2.80GHz · Windows 10 Home/11 upgrade 64-bit · 16GB DDR4 RAM · 1TB SSD and 1TB HDD; Graphics: NVIDIA Geforce GTX 1060 - 6GB GDDR5 VRAM; Software: Poser Pro 11x
A_Sunbeam posted Thu, 10 January 2019 at 5:15 AM
Download just the two updates.
jartz posted Thu, 10 January 2019 at 3:12 PM
Thanks @ A_Sunbeam
willyb53 posted Thu, 10 January 2019 at 6:14 PM
operaguy posted at 6:13PM Thu, 10 January 2019 - #4343371
I can not be sure it will work for you, but there is an older (and free) script from D3d that does the conversion well for me. http://d3d.sesseler.de/index.php?software=poserpython&product=figure2prop
Bill
People that know everything by definition can not learn anything
ErickL88 posted Sat, 12 January 2019 at 10:57 AM
After having updated, is anyone else experiencing, that the libraries folder won't stay open anymore on a restart? Closing the PP11 and restarting it later again, every folder in the libraries are closed now (using the default library, not a 3rd party plug in). For others a blessing maybe, but I always disliked this behavior. From previous versions I think to remember, that there was an option to tick "re-open folder", or something to this extend. I cannot find this anymore now.
FVerbaas posted Sat, 12 January 2019 at 11:08 AM Forum Coordinator
FVerbaas posted at 6:00PM Sat, 12 January 2019 - #4343387
Well here is the script, slightly pimped relative to original. Feel free to use and try. Testing revealed a technical problem with some figures. I found it working well for PE, V4, Dawn, Pauline and Roxie. There are problems that I cannot explain for Bella and Rafaella. Same module in Poser works differently for some reason. The exporter works correctly but the .obj file has zero length. Anyone who can shed some light on the why please let me know.
NOTE: THE SCRIPT WORKS ONLY WITH THE RECENT UPDATE OF POSER !!!!!!!
FVerbaas posted Sat, 12 January 2019 at 11:32 AM Forum Coordinator
Sorry, Correction.
Something going wrong again. Apologize! I have taken down the file.
FVerbaas posted at 6:31PM Sat, 12 January 2019 - #4343522
FVerbaas posted Sat, 12 January 2019 at 12:02 PM Forum Coordinator
Problem solved, New link:
PerroLoco posted Sat, 12 January 2019 at 12:09 PM
Whet the hell is wrong with the Smith Micro Poser web site...? I keep getting can't connect errors.
Miss B posted Sat, 12 January 2019 at 5:27 PM
The SM servers were down for a while earlier today, but they're back up and running, so try accessing their site again.
_______________
raven posted Sun, 13 January 2019 at 7:23 AM
@ErickL88 The update removes the “Reopen Folders Toggle” option from the content Library tab.
ErickL88 posted Sun, 13 January 2019 at 9:35 AM
