Subject: Texture lines in Firefly - not in Superfly
pixpax opened this issue on Jan 09, 2019 · 5 posts
pixpax posted Wed, 09 January 2019 at 6:31 PM
Hi all. Hope somebody can figure this out. I have tried numerous settings in Poser 10 but nothing works for me. This is the problem: I get white lines in renders in Poser 10 - at all seams:
Error1.png but not in Poser Pro 11, Superfly render:
It´s of course the exact same texture, pose and lights. What happens here? Please help!?
-Anette
randym77 posted Wed, 09 January 2019 at 10:10 PM
Oh, man. I remember this being a problem with Firefly when Firefly was the new renderer. (Yes, I'm old. Get off my lawn!)
Try turning off smooth polygons. If that doesn't work, turn off texture filtering for the affected items (in the material room).
pixpax posted Thu, 10 January 2019 at 6:57 AM
HI
Thanks for helping me out. I actually remembered having the problem when you mentioned it :) But not how it was solved though.
bagginsbill posted Thu, 10 January 2019 at 8:26 AM
In render settings, lowering min shading rate improves results of texture filtering but will increase render times and memory used. You can also try different versions of texture filtering (or None), with the newest one being the most reliable and not needing extremely low min shading rate: Crisp.
pixpax posted Thu, 10 January 2019 at 4:35 PM
Thank you SO much. Lowering the shading rate helped quite a bit. At 0,11 the lines are completely gone! And I could put the filtering back to crisp without messing things up! :-).
