mmitchell_houston opened this issue on Jan 10, 2019 · 8 posts
mmitchell_houston posted Thu, 10 January 2019 at 12:54 PM
I'm experiencing an odd problem in Poser Pro 11. In the Fitting Room (which I have used before in earlier versions of Poser) the "brush" tool is no longer showing me which polygons are being affected. I should see green/yellow/red polygon points to indicate which ones are being affected by the edits I'm making, but I don't see anything. However, the brush DOES seem to be working (although very slowly).
In other words, I can make edits but can't see what I'm doing (if that makes any sense).
Has anyone else had any issues similar to this?
System: Lenovo Legion Pro 7 16IRX9H Laptop | Windows 11 Professional | 32GB RAM | 14th Gen Intel® Core™ i9-14900HX | Nvidia RTX 4090 Laptop GPU 16GB 9728 CUDA Cores
mikemitchellonline.blogspot.com | Poser Noir Comics Tutorial | Illustrations Honored by Renderosity
RedPhantom posted Fri, 11 January 2019 at 6:18 AM Online Now! Site Admin
Are you sure the display weights didn't get unchecked?
mmitchell_houston posted Fri, 11 January 2019 at 12:17 PM
RedPhantom posted at 12:17PM Fri, 11 January 2019 - #4343450
I shall check! Thank you.
mmitchell_houston posted Fri, 11 January 2019 at 12:52 PM
RedPhantom posted at 12:51PM Fri, 11 January 2019 - #4343450
Rats. That wasn't it.
I have decided to go back into Poser 2014 (on my old computer) and confirm that I'm doing everything right, then try the settings in another build of Poser 11 (again, on yet another computer) and then come back here to see if it works. This will eliminate user error from the equation, and then I can shift focus to video drivers or other things like that.
Glitterati3D posted Tue, 05 February 2019 at 7:44 AM
I don't know what figure you are using, but before you go into the fitting room, make sure subdivision is turned off on everything you are using. The brush is hard to control on a subdivided figure.
mmitchell_houston posted Tue, 05 February 2019 at 9:19 AM
Glitterati3D posted at 9:18AM Tue, 05 February 2019 - #4345340
I don't know what figure you are using, but before you go into the fitting room, make sure subdivision is turned off on everything you are using. The brush is hard to control on a subdivided figure. Thanks. I'll give that a shot, too (that could explain some issues I've had in the past). But that's not the issue I'm having; I just don't see the brush effect at all. (BTW: I'm using Michael 4).
RedPhantom posted Tue, 05 February 2019 at 3:21 PM Online Now! Site Admin
Maybe check if you have screed or opengl selected and try the other.
mmitchell_houston posted Wed, 06 February 2019 at 9:09 AM
RedPhantom posted at 9:09AM Wed, 06 February 2019 - #4345394
I have not looked at that! I'll check!
